all warning lights turn on in speedometer..
Old Jan 1, 2008 | 12:16 PM
dimas_tp's Avatar
i just got stuck in icy road today and made my engine to do high rev in order to get out from icy road. After i got out, my vdc, spin, and ABS warning lights turned on and the speedometer didnt work at all, only fuel gauge and rpm which worked. do you guys know what happens with my car?
Old Jan 1, 2008 | 12:24 PM
elayman's Avatar
did you restart your car? thats weird
Old Jan 1, 2008 | 12:26 PM
dimas_tp's Avatar
yes i did but nothing happened
Old Jan 1, 2008 | 12:28 PM
elayman's Avatar
take it in to the dealership if its still under warranty
Old Jan 1, 2008 | 12:33 PM
sliderg35's Avatar
You get the same effect after running on a dyno. I should stop shortly after normal driving resumes.
Old Jan 1, 2008 | 12:55 PM
jonnylaw's Avatar
^+1 happened to me when my g was on a dynojet. A couple minutes of normal drivingaround the shop cleared it.
Old Jan 11, 2008 | 11:48 PM
SpeedNStylez_JL's Avatar
My has been on for days!! I drive normally and it wont go away. Anyone have info on this. Thanks
Old Jan 13, 2008 | 03:04 AM
dimas_tp's Avatar
you should just wait, my car takes about two days to be normal again
Old Jan 14, 2008 | 11:54 AM
It has been a week since its been on. I will try to disconnect the battery overnight. Thanks
Old Jan 14, 2008 | 12:04 PM
ttrank's Avatar
Grocery getter
Try that and if not take it in. You should also check to see if your ABS fuse is ok, it's behind the battery. I know when I pulled mine at the drags one time to do burnouts the same thing happens, even the speedo stops.
Old Jan 15, 2008 | 03:53 PM
Its weird cause my speedo works just fine...I just disconnected it right now while im at work. hopefull after work it works out fine.
Old Jan 21, 2008 | 06:07 PM
Still not good...Do you guys think it has anything to do with my brakes? My brakes have been acting up lately...
mjfenix
Jul 17, 2015 02:07 PM
