Heat problem
Old Jan 4, 2008 | 08:23 AM
mrimage's Avatar
Heat problem
i recent have troubling with my heat. my car have 80,000 on it, when my car is idling i get a little heat, but when i drive it are rev it i get heat. my friend at the dealer bleed it and it was fine until this morning it start same problem again. anyone ever have this problem?
Old Jan 5, 2008 | 11:50 AM
Bimmer G's Avatar
Yeah man i have the same problem. I just checked out my car at work and its looking like the T-stat is stuck closed so when your at idle its not opening to its full open. But when your driving or revvingup its pushing the coolant though and opening it. I'm going to replace mine this week. I'll post back up with the outcome.
Old Jan 5, 2008 | 03:51 PM
mrimage's Avatar
ok thanks
Old Dec 5, 2008 | 04:22 PM
Hanoon's Avatar
did this solve your problem?
Old Dec 5, 2008 | 04:40 PM
Q45tech's Avatar
Common problem by design no/low heat at idle warns owner to replace worn out thermostat.....................and 80k is sure worn out.
Old Dec 5, 2008 | 04:44 PM
Hanoon's Avatar
i had same problem with no heat and then i diod the bleeding thing explained in some other post here and its better now .... i get low heat but better than nothing
Old Dec 13, 2008 | 09:14 AM
tom's_Z's Avatar
You might have air pockets in your radiator tubing.....take the radiator cap off when cold, and slowly squeez the tube leading out of the radiator, if you see bubbling and the level goes down slowly, that means you had some pockets in there. It wont circulate correctly with air pockets in there. Anyway, then refill it and ur done. I wound up putting a quarter bottle in.
this fixed my low heat problem, hope it helps.
Old Dec 13, 2008 | 09:34 AM
RBull's Avatar
Rated M
Check the rad cap. mine was defective at low miles.
Old Dec 14, 2008 | 04:45 PM
vq35dedriver's Avatar
I've got the same problem actually no heat at all on idle at operating temp but once I get going I have a 5at I've got to drive over 4000 rpm to get heat in the car. I only have 38000 miles on an 06 coupe, I plan on calling the dealership Monday cause it's still under warranty. You guys think it could be the t-stat?
Old Dec 29, 2008 | 09:38 AM
DjGenuine's Avatar
Same problem here and I only have 19K miles...have an appointment with the dealership today, hopefully its a quick fix.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
Jnm07
Sep 5, 2015 01:16 AM
