Air filter R&R question
Old Jan 9, 2008 | 08:42 PM
Blue Lion's Avatar
I am trying to replace my air filter (in the engine, not the cabin air quality filter). I found 2 latches on top and 1 on each side and I loosened them. I still can't get the opening far enough apart to remove the old filter and replace it. Do I just pull apart harder or am I missing something? This seems like it would be simple. The owner's manual was no help.
Thanks.
Old Jan 9, 2008 | 09:02 PM
Memphoman's Avatar
I loosen the clamp on the flex hose, disconnect the Mass air sensor plug, remove the one screw right side, and roll the filter housing up and toward the engine, allowing me to clean the housing assy as well as easier access to the filter itself.
Old Jan 9, 2008 | 10:31 PM
TheKnite's Avatar
I believe there was a write up. Use the search function and see if it helps.
Old Jan 9, 2008 | 10:50 PM
Beebo's Avatar
http://www.infinitihelp.com/Ownershi...G35/AirG35.htm
Old Jan 10, 2008 | 09:29 PM
Blue Lion's Avatar
Thanks Beebo. That's quite involved for an air filter. I would never have figured it out.
Old Jan 16, 2008 | 11:16 AM
killahb36's Avatar
sorry to be a super noob but when replacing the air filter the side with the invaginations should face the front of the car correct??
Old Apr 4, 2008 | 11:40 PM
bythabay's Avatar
It'll be obvious the way it fits. I posted an air filter replacement DIY video that you can watch here:
https://g35driver.com/forums/g35-sedan-v35-2003-06/183421-diy-video-series.html
Old Apr 5, 2008 | 02:10 PM
ckg35's Avatar
Thanks.
The first time you do this is the hardest. Only takes about 5 minutes each time after that.
Old Apr 6, 2008 | 08:22 AM
twin001's Avatar
Invaginations....I'm going to see how many times I can say that next week.
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
derres
Aug 28, 2015 03:27 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
vstypicals
Jul 20, 2015 10:55 PM
justgotg35
Jul 19, 2015 12:33 PM
