Air Filter For Procharged G35/help!!
Old Feb 12, 2008 | 12:36 PM
IrockAG35's Avatar
Ohio G Club moderator
im down for a group buy if theres something available,a place here in louisville said they can make something work and guaranteed 'no spell check' it would look good, but they wanted like 300$...good deal?
Old Feb 12, 2008 | 12:37 PM
IrockAG35's Avatar
Originally Posted by ttrank
You can make a cut, add two bends and couplers and make something like I did for my Greddy kit.
thats a sweet setup,im not sure it would work with procharger kit,your turbo's look like they sit much lower
Old Feb 13, 2008 | 10:48 AM
ttrank's Avatar
Grocery getter
Yes the turbos sit lower but the driver sieintake is right where procharger is. I just extended the pipe out there which you could do the same thing.
Old Feb 13, 2008 | 11:13 AM
IrockAG35's Avatar
good looking out man,i think i may give that a try,not only does it look good, but it get nothing but cold air to feed the blower...thanks
Old Feb 13, 2008 | 12:42 PM
ttrank's Avatar
Grocery getter
It's not hard to do at all.
Per QuadCam's information I got the bends and couplers from boostcontroller.com and then the filters are AEM dryflow.
Then you need to cut out a hole for the pipe and trim the bends as needed. I also had to trim my grille a little but mine is a sedan so yours may be different. Did you have to bend your A/C lines out of the way for the procharger install? If not you may also need to move them over a little. It sounds like a lot but was not bad at all. I did it in a couple hours taking my time with a few beers in me.
Old Feb 13, 2008 | 12:47 PM
ttrank's Avatar
Grocery getter
Here's where the old Greddy filters sat:
Old Feb 13, 2008 | 07:29 PM
G37Rider92649's Avatar
Just talked to GTM and they're actually working on it right now, again like I said, I'll post up pics when it's done. If you're in socal go to GTM for it, they're the ones that introduced it to me in the first place anyways.
Old Feb 14, 2008 | 12:56 PM
ttrank's Avatar
Grocery getter
Originally Posted by HomieG35
Looks like you have more space than us...
Yes but yours has the perfect spot right there to extend it out just like I did mine.
Old Feb 14, 2008 | 01:32 PM
IrockAG35's Avatar
the way yours is setup is ideal, im going to try and set mine up like yours..very informative...ill have to wait until it warms up..its only been about 25 here lately..hopefully things will work out
Old Feb 14, 2008 | 01:35 PM
IrockAG35's Avatar
ac lines look really reallly tight though...how should i bend them?...what tool to use...plubming pipe bender?
Old Feb 14, 2008 | 05:32 PM
Xblackg35X's Avatar
i used my hands to bend them just do it very very very carefully. it will take a little while so dont rush it.
Old Feb 14, 2008 | 09:33 PM
Xblackg35X's Avatar
<a href="http://img136.imageshack.us/my.php?image=0214082004ajs7.jpg" target="_blank"><img src="http://img136.imageshack.us/img136/6624/0214082004ajs7.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
<a href="http://img136.imageshack.us/my.php?image=0214082004pc8.jpg" target="_blank"><img src="http://img136.imageshack.us/img136/6325/0214082004pc8.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
just installed my intake today for my procharger. took alot of time and i still have a little cutting to do to the grill and it will be complete.
Old Feb 15, 2008 | 11:33 AM
IrockAG35's Avatar
im jealous..lol!! mines @ infiniti right now...damn cd player went out last week..so i brought it up there under warranty..when i get it back...im def going to get this project going!!
Old Feb 15, 2008 | 07:32 PM
  #30
Xblackg35X's Avatar
you should be jealous lol.....it takes time man. i had to use a hack saw blade a drill bit to start the hole and a dremel. if you dont have a dremel then your SOL! and its a PITA. the intake is the one that comes stock with the kit when you purchase it for a 350Z. it works perfect. if you wanna know anything else or want any pics just pm me. ill be more than happy to help you homie.
