Hood Support Mod?
Hood Support Mod?
Does anyone know, or done a mod to remove the rather "cheap" hood support for some shock type supports?
Is it even possible? My I35 had the hood struts and it was so convenient to have the hood open on its own and stay open without that silly rod....<font color=blue>2old4this</font color=blue>
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Re: Hood Support Mod?
My dealer made it a point to tell me that the G35 is the only Infiniti to have a hood prop, and that it is because the hood is aluminum and cannot be properly supported with gas shocks.
Kevin
04 Diamond Graphite Coupe - FULLY loaded
Windows up with OEM Remote
Kevin
I wasn't aware that the hood was aluminum......
it sure feels mighty heavy for an aluminum piece.....
Kevin...how did you get your remote to operate the window up function....was this a mod as well? <font color=blue>2old4this</font color=blue>
There is a super long thread on here about the windows up with OEM remote... its under the 'technical' forum. In short, it is a microcontroller based circuit I created for my car and I am now in the process of mass producing them for sale. For more info check out www.kptechnologies.net
Kevin
Kevin
No faith in my wealth of useless knowledge?
Haha! The only reason I remembered that it was aluminium is because as soon as my salesperson told me I made a mental note that using the hood as a ground for a mercury tilt switch would not work!
Kevin
Kevin
