5.2whp for cheap
Old Feb 26, 2008 | 05:39 PM
mediumred91lx's Avatar
use ngk plugs, you'll be happier in the long run.
Old Feb 26, 2008 | 05:47 PM
keegur's Avatar
ive always used NGK plugs but if you havent ever tried these i wouldnt know , but i might as well try it wont hurt
Old Feb 26, 2008 | 07:27 PM
citymunky's Avatar
Originally Posted by jlinc04
Its colder ones for FI and Hotter ones for N/A, right
Yes, one step colder for FI
I read this somewhere:
"Typically, for every 75-100 hp you add, you should go one step colder on the spark plug's heat range. A hotter heat range is not usually recommended except when severe oil or fuel fouling is occurring."
Old Feb 26, 2008 | 07:40 PM
Calvin's Avatar
Overglorified Altima
because 5.2whp is going to make so much difference.
Old Feb 26, 2008 | 07:42 PM
redlude97's Avatar
Originally Posted by BlueDevilBAMF
Interesting idea... certainly can't hurt... anyone know what a set of the OEM plugs costs?
actually it could possibly hurt, both your pocketbook and your engine
Old Feb 26, 2008 | 08:07 PM
BlueDevilBAMF's Avatar
So - any idea what the OEM plugs cost?
Old Feb 26, 2008 | 08:21 PM
BolivianFuego's Avatar
How so?
Old Feb 26, 2008 | 11:17 PM
Originally Posted by BolivianFuego
How so?
It seems obvious to me that bad spark plugs could be very bad for your engine (I retract my "certainly can't hurt" statement), but I'd like to hear some specifics from someone as knowledgeable as redlude.
Don't be surprised if he doesn't respond because he feels your question is insulting to his level of technical expertise.
Old Feb 27, 2008 | 12:03 AM
How could some spark plugs be bad for a g35? I dont understand, as long as they are gapped to factory spec? Unless i am missing something? Is it that these would make you run lean(detonation), more so than the fac. spec and this is where the power is coming from?? Is this what is trying to be said?
Old Feb 27, 2008 | 01:26 AM
redlude97's Avatar
How so?
If they don't do jack, then you wasted your money, there was some speculation on my350z that the reason they may make hp is that they are basically one step "hotter" spark plug, which could possibly do damage to the engine. I'm not saying it will, i'm saying its possible, and people shouldn't just go installing random parts that claim to make hp onto their car without at least a few independent tests to back it up.
Old Feb 27, 2008 | 01:49 AM
Beebo's Avatar
Old Feb 27, 2008 | 01:58 AM
TIAN's Avatar
Hold The Line
Originally Posted by Beebo
I lol'd at your avatar
Old Feb 27, 2008 | 02:34 AM
Still2Slow's Avatar
I find this much gain hard to beleive. Even if you indexed them, the most I ever heard of was maybe 1-3 hp gain with denso.
Old Feb 27, 2008 | 09:06 AM
caelric's Avatar
There was also speculation that because of the capacitor inherent to the plug, there was some slight change of timing. If you are already on the threshold with timing, a 1 degree difference can make some HP, until it goes BOOM!
Old Feb 27, 2008 | 01:34 PM
  #30
DaveB's Avatar
Wait till 3rd party dynos are done for these plugs before believing what's been stated in a magazine.
