Rough Idle after MD spacer Install- HELP
Old Feb 28, 2008 | 10:51 PM
GD-Up's Avatar
Hello All!
I installed my 5"16 spacer but the car isn't running right. It starts fine and idles ok for about 30 seconds at the normal range 750-850 but then drops to 480-500ish and almost stalls before it trys to get back to normal.
Also I was expecting more of a boost from this upgrade...could the idle issue be affecting my performance?
I did the ECU reset and the throttle relearn...but the problem still persists.
Any ideas on how to fix...and should I be expecting more of a boost in power?
Thanks!
(ps I got the isothermal copper spacer)
Old Feb 28, 2008 | 11:41 PM
Texasscout's Avatar
Did you follow the torquing specs and pattern? You may have a vacuum leak.
Old Feb 28, 2008 | 11:45 PM
crashnburn's Avatar
wouldnt vac leak make it idle high... im having kinda same problem after i just cleaned my throttle body... except for the norm 650-750 range im more like 900-1200.. made the g little more responsive but i through a SES for code 1122
Old Feb 29, 2008 | 02:27 AM
Skaterbasist's Avatar
Retired SuperMod
Normal idle is @ ~600. You either have a vacuum leak (loose hose) or probably have enough breathing mods to give you a rough idle... although it seems you're having a bigger issue than just a "rough" idle.
Check all the hoses & make sure there isn't any leaks.
Also, if you have enough breathing mods, I suggest you get your idle raised. My idle was rough due to my breathing mods (intake, spacer, exhaust, test pipes). I got my idle raised from 600 (stock) to 850 and it idles so much better.
Old Feb 29, 2008 | 02:37 AM
GD-Up's Avatar
Hi all,
Thanks for the help!! It is much appreciated.
I'm not sure exactly what was wrong so I took the space out and reinstalled the whole thing again.
So far it seems to be much better. Idle was a bit high at first but I reset the ECU and all seem to be okay!
THANK YOU!
Old Feb 29, 2008 | 02:39 AM
JOKER's Avatar
CLUB MODERATOR
the important thing when bolting down the spacer is to bolt down the sides first and just barely bolt down the middle.
Cuz if you bolt down the middle too hard it will bring up the sides and you will have a leak and it will cause your idle to be all over the place.
Old Feb 29, 2008 | 02:40 AM
GD-Up's Avatar
Also, if you have enough breathing mods, I suggest you get your idle raised. My idle was rough due to my breathing mods (intake, spacer, exhaust, test pipes). I got my idle raised from 600 (stock) to 850 and it idles so much better.[/QUOTE]
Thanks for the info!! I have a dual exhaust, Intake (and spacer now). Does "too many" breathing mods reduce performance...(too much of a good thing is bad?)...just curious
Old Feb 29, 2008 | 02:44 AM
Retired SuperMod
Not at all. In the contrary, most breathing mods will increase your performance. But after you have enough breathing mods, you will run lean and will probably have a rough idle.
Getting a tune/flash will improve your performance much more. It's definately something you should look into (get your idle raised while your at it too).
Old Feb 29, 2008 | 02:47 AM
Retired SuperMod
Good points. Best thing to do is get all of the bolts down in place without tightning them. And leave the real torquing at the end.
Old Feb 29, 2008 | 04:33 AM
JOKER's Avatar
CLUB MODERATOR
still do not tongue the middle at all.
Cuz spacer only goes around the plenum. Middle bolts don't get any spacer. So there is a space between the plenum and the engine. So if you torque them down to the specs you still will raise the sides cuz middle is not being pressed against nothing.
Old Mar 17, 2008 | 03:00 PM
GD-Up's Avatar
Sorry to bump this after all this time..
Just wanted to say thanks to Joker!!.. looks like the plenum was not bolted down as best as it should be.
THANKS!
Old Mar 17, 2008 | 03:02 PM
06g35meister's Avatar
with my flywheel, the car stalls when i push in the clutch... i have an intake, but it seems the RPM's fall much quicker... should i also raise my idle? where can i have this done?
Old Mar 18, 2008 | 01:37 AM
KapVu's Avatar
My car idles around @ ~450/500. I have the 5'16" plenum spacer, K&N filter w/ Z-tube, and FI exhaust.
The funny thing is that my idle before I installed the spacer was already at ~450/500. Is that normal? But when I turned the heat on my idle would raise to ~850/900 (before spacer install, and same when spacer install).
Also, after installing the spacer, on a cold start it idles at around ~1100 but then after the car warms up it drops down to ~450/500, is that normal?
Thanks for any responce.
Old Mar 18, 2008 | 04:25 AM
G37Rider92649's Avatar
You didn't have to re-install it, install it again and just keep driving it. Let the computer learn, after I install my test pipes my idle was low, sometimes it won't even start, stalls at start up, too much air flowing through from all my breathing mods. Just drive it around and the ecu will learn it's idle, and then where it idles at after, wether it's 500 or 600, that's its new idle where it stables, don't worry, just drive you'll be fine, in the future you can raise the idle/ get a ecu re-flash tune
Old Mar 20, 2008 | 11:00 PM
arsine's Avatar
KapVu, the revs should be a bit high after a cold start to get the block warmed up (mine hangs at ~1600 rpm before settling to 600 rpm) and the revs will go up some when you use your heat/ac (~200 rpm). Your idle seems on the low side but proportionately, it seems about normal
