Stablizer Bar
Stablizer Bar
Hi All --
Is there a bar that could be installed across the engine on a G35 Coupe 6MT similar to those on the 350Zs? (without the need to remove the engine cover and the need to be leaving it off). There are two bolts on either side that seem to have been designed for this, but are not used.
Kaveh
Kaveh
https://g35driver.com/forums/suspension-vendor/163289-its-back-richie-front-strut-bar-v-2-group-buy.html
if you have a spacer, then the engine cover may have to be removed.
Originally Posted by kavehdr1983
Forgot to ask, is this easy enough to be installed by a non mechanic or is doing so recommended?
Kaveh
Kaveh
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
