Help Car Wont Start!
I went to go start my car today and nothing happened. All of the lights came on the radio works, and everything the only thing that is not right is where it says what gear its in like P,R,N,D, its just blank. Nothing is there i will go thew the gears if i turn the key to on and put my foot on the brake but it does not show anything on the display. Any ideas, i have my negative off right now im gana try resetting my ECU. I was thinking it could be a fuse but i dk wat one also the brake peddle is depressed and will not release not sure if that has anything to do with it.
12 hours I believe. There is also a way to reset the ECU without disconnecting the battery, lemme find the thread.
Here's the thread:
https://g35driver.com/forums/showthr...ight=reset+ECU
Follow Msedanman's instructions, it may take you 10+ tries to get the timing just right, but it works.
Here's the thread:
Originally Posted by jjyellow
when u put it in neutral, does the N show on the indicator. Might be something with the neutral safety switch
Guest
Posts: n/a
Reset is a good first step. But it may be the break booster or a brake switch relay. Most of the time with your hand on the shifter you can push the brake down maybe half an inch (right at the point the tail lights illuminate) and hear/feel a click in the shifter which lets it out of park. If that is the neutral safety switch on these cars than that may be the problem.
Check your brake fluid just for ****s and giggles?
Originally Posted by g35rcr
your crank sensor might be bad...when you try to turn your car over does it try to crank but not turn over or is your car just dead? if its not cranking your starter might be bad or your battery could just be really low
