Stillen Z-Tube intake or 5/16 plenum spacer?
Old Apr 13, 2008 | 04:46 AM
Beebo's Avatar
Originally Posted by xfuz1on
so looking at the dyno charts i see that the 1/2 spacer gives more hp & tq. Why is everyone recommending the 5/16 over the 1/2 though? sorry for the questions
because the 5/16 gives power throughout the RPM range
Old Apr 13, 2008 | 12:19 PM
Bimmer G's Avatar
There right about the power gains in the 5/16 spacer. I installed altered atmosphere's angled spacer. You can hear the different cause all 6 cyl's are getting equal air. All the intake will do is direct the air to the throttle body, and thats maybe a 1 HP gain.
Old Apr 13, 2008 | 12:25 PM
05G356MT's Avatar
spacer if you want more power and intake for the sound.
Old Apr 13, 2008 | 12:29 PM
gary c's Avatar
Which to buy first....?
There's only one spacer I'd consider since I know it works and comes with
everything needed to install....MotorDyne. Both the intake and the spacer
compliment each other since you're getting more air into the plenum. I have
both and wouldn't change a thing, this combo along with a cat-back free
flow exhaust make HP!
Old Apr 13, 2008 | 12:41 PM
xfuz1on's Avatar
so what if i don't need to cover the stock engine cover? I see more people getting the 5/16 over 1/2. I don't really mind if i have the stock engine cover off. Which would be a better choice? I have a 5 AT btw. sorry for all the questions
Old Apr 13, 2008 | 12:45 PM
Bimmer G's Avatar
Well i took off my cover when i did my spacer. I painted the top part of the plenum black. I too have a cold air intake as well. It helps a lot as a combo
Old Apr 13, 2008 | 01:06 PM
Beebo's Avatar
i say still go with the 5/16... bigger isnt always better my friend...
Old Apr 13, 2008 | 01:11 PM
johnjohn077's Avatar
Either size will do.. its either the normal HP gain with the cover with the 5/16 or the normal HP gain +1 and no cover with the 1/2" ... in any case you'll feel and hear the extra kick in your G....
Old Apr 13, 2008 | 01:24 PM
Da-G-SpoT's Avatar
I have the 1/2" and i did not have to remove my cover, it actually fit right in. Is there something wrong with my car/engine/spacer? BTW i ordered it directly from Tony @ Motordyne so i know its not a fake or bad quality. I have pics if you guys would like to see....
Old Apr 13, 2008 | 01:47 PM
silver g's Avatar
Get the spacer.
Old Apr 13, 2008 | 01:50 PM
Dr. Ephil's Avatar
If you're on a tight budget forget about the spacer,$240,for now. Advance the timing 2 degrees,$75. Performance wise it's close to/the same as the 5/16 spacer. The program used to advance the timing makes a difference as well. The shop where I had mine done used Cipher.
I have the Stillen ztube and it is a worthy mod to consider. Improves gas mileage. Any aftermarket tube is better than the stock tube.
When you eventually buy a spacer,get an iso-thermal one. You'll probably have issues with heat soak, considering where you live. As for replacing the engine cover,if you have a 1/2" spacer AND a strut bar you can't replace the cover.
Hope this helps your decision,cheers!!!
Old Apr 13, 2008 | 02:51 PM
O HELLA JDM's Avatar
5/16 Ftw
Old Apr 14, 2008 | 05:59 PM
g35_infinit's Avatar
how about a kinetix plenum? will there be much of a difference between the spacer? im actually considering this sort of mod too.
Old Apr 14, 2008 | 06:09 PM
Lolly Baggins's Avatar
I guess I am going to feel some difference?
I am going stock to immediately this : Stillen Hi Flow intake, Z-Tube, K&N Drop in filter, MREV2, Motordyne 5/16" spacer.
Old Apr 14, 2008 | 08:48 PM
  #30
Beebo's Avatar
you cant have both... lol
