stillen engine damper install help
Old Apr 26, 2008 | 12:19 PM
KapVu's Avatar
attempting to install the stillen engine damper today. The instructions are kind of unclear and there was no DIY. I searched but couldn't find clear pictures either.
I don't understand where it says to relocate the grounding wire? Can some one show me with pictures which wire has to be relocated where? I have an idea, but want to be 100% sure.
Also, does anyone have a pictures of how the A bracket is installed? This will help also.
Thanks to anyone that can contribute! Thanks.
Old Apr 26, 2008 | 12:40 PM
Ghayes23's Avatar
I can try to get some pictures up this evening.
Old Apr 26, 2008 | 02:40 PM
KapVu's Avatar
that would be great. Thanks for helping.
Old Apr 26, 2008 | 04:46 PM
G37Rider92649's Avatar
Stillen didn't give you a clear description on the instructions? I remember mind had a good amount of photos, but then again when I popped my hood and looked in and compared to the instructions I was like Fvcccccck that haha
Old Apr 26, 2008 | 05:23 PM
Xblackg35X's Avatar
there is gonna be 1 bolt holding the groumd wire to the frame rail. fallow that bolt all the way up its gonna split into 2 grond wires. disconnect those 2 and run them both under the radiator hose. put the little ground wire bacj in it original spot and mount the other on top of the gold bracket
Old Apr 26, 2008 | 05:24 PM
Xblackg35X's Avatar
sorry for the misspelling i just woke up
Old Apr 26, 2008 | 09:31 PM
KapVu's Avatar
I need pictures if anyone can provide them. Thanks. I'm sorry it still not that clear to me. Thanks.
Old Apr 29, 2008 | 01:27 PM
KapVu's Avatar
after finding a few pics online, I figured it out. It's a tight squeeze and kind of hard to install, but i got it to work.
I don't feel any vibrations in the cabin, but definately feel a difference in 1st, 2nd, 3rd gears. Feels like there is no car jerking, smoother shifting, and car overall feels very solid.
Old Apr 29, 2008 | 02:58 PM
Ghayes23's Avatar
Sorry I never got those pics to you. I couldn't get any that were clear. I'm glad you figured it out though.
Old Apr 30, 2008 | 09:39 AM
KapVu's Avatar
it's all good. i'm curios though, i installed the damper very tightly. Even though the damper doesn't move at all, it can still "twist" because the ends are adjustable because of the ball head design on each end link. Is that normal?
The part I'm talking about is the part where the screws goes through on each end. It's design so it can be installed in various angles. But once installed, it can still be moved.
Let me know if you need me to clarify.
Old Apr 30, 2008 | 01:18 PM
Ghayes23's Avatar
That kind of movement is okay I think. The brace still keeps the engine from moving from side to side.
derres
Aug 28, 2015 03:27 PM
RA102223
Aug 15, 2015 09:24 PM
Team STILLEN
Aug 10, 2015 08:17 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
