Hose help...
Old May 9, 2008 | 01:54 AM
SxExCx's Avatar
Hose help...
Im looking to replace my upper heater hose...what size is it?
Old May 9, 2008 | 02:06 AM
ttrank's Avatar
Grocery getter
Why not just get a VenAir or Samco kit?
Sorry, I don't know the actual size.
Old May 9, 2008 | 02:12 AM
k67p67's Avatar
It's an articulated hose. You should buy an OEM hose or, as ttrank suggested, a Samco or Venair hose set.
Old May 9, 2008 | 03:13 AM
SxExCx's Avatar
I have venair, looking to replace it with something custom to reroute..come on you guys should know me better.
Old May 9, 2008 | 03:48 AM
k67p67's Avatar
Changing radiators? You can't change the upper coolant hard line. I mean you "could" but it would be a huge PITA. If you go with a metal radiator, you could use a steel-braided hose like this>>>
Old May 9, 2008 | 10:26 AM
SxExCx's Avatar
I already know what hose I am getting, I juts need to know what size. This is the one I need the size of:
Old May 9, 2008 | 04:14 PM
k67p67's Avatar
The hose in that pic of Marty's car is obviously not OEM. He had an AN fitting welded to his upper coolant hard line. I think he used a -10 hose and fitting as did I. The OEM hose is articulated and I believe is either a -10 or -12.
Old May 9, 2008 | 05:16 PM
SxExCx's Avatar
thanks Kurtis, do you know that the standard measurement is on that?
Old May 9, 2008 | 06:03 PM
k67p67's Avatar
What exactly are you trying to do?
Old May 9, 2008 | 06:45 PM
SxExCx's Avatar
replace the hose
I'm getting a stainless steel flex hose so I can route it to run under the cam covers
Old May 9, 2008 | 06:47 PM
SxExCx's Avatar
I am going to run it like this:
Old May 9, 2008 | 06:57 PM
EricIsKlumzyee's Avatar
good luck sean =) damn soo many clean engine bays ._.
- Eric
Old May 9, 2008 | 08:02 PM
k67p67's Avatar
I would suggest you have a shop weld an AN adapter on there to facilitate running the hose in that direction. You'll probably have to use a fitting similar to this
Steel-braided hose won't turn tight corners so you'll have to plan out the hose run carefully to get under the vtc covers but over the belts. If you use a -10 adapter for the upper hard line, you can use -10 hose and a -10 fitting. You'll probably need a -12 clamp for the other end of the hose.
Old May 9, 2008 | 08:23 PM
SxExCx's Avatar
ill look into it, thanks
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Hogbone
Sep 28, 2015 06:44 PM
lavtxa
Sep 21, 2015 11:51 AM
G35CO
Sep 4, 2015 09:27 AM
