replace coil pack?
Old May 10, 2008 | 03:13 AM
High3nd_SD_g35's Avatar
replace coil pack?
has anyone replaced their coil pack? my problem is that the check engine soon light came on and so i read the code and it states multiple cylinder misfire i changed out all the spark plugs and still the same code comes up and yes i did erase the code after changing the spark plugs...anyone help
Old May 11, 2008 | 01:06 PM
Boost99A4's Avatar
stupid question, but is the car actually misfiring? And what kind of plugs did you use?
Old May 11, 2008 | 02:03 PM
Well as far as the car misfiring thats a no but the damn engine code comes up after i erase it and as far as plugs i use NGK iridium
Old May 12, 2008 | 10:54 AM
Boost99A4's Avatar
thats wierd... by the way our car takes the ngk 6240 or plfr5a-11 which is a platinum plug not iridium... how many miles are on the car? and are you sure its not misfiring at idle? what code did you get?
Old May 12, 2008 | 10:57 AM
SDGenius's Avatar
what kind of gas do you use? have you looked for exhaust leaks?
Old May 12, 2008 | 03:46 PM
Curt G's Avatar
Do you have a K&N or other oiled gauze filter?
Old May 12, 2008 | 09:15 PM
the car has 22,000 and no its a clean run at idle damn and as far as the code number im not sure but i do remember that it states random/multiple cyclinder misfire...gas usage would be shell premium and as far as the k/n filter yes i do i just installed that last weekend...
Old May 12, 2008 | 11:12 PM
Boost99A4's Avatar
i really haven't seen these cars give coil pack problems... see if you can get me the code so that i can try and help you... if you get a random multiple cylinder misfire, if you drive the car for a while you usually will also get a specific cylinder, and then if thats the case you can change the coil pack... loose grounds can also cuz that code to come up, but if you haven't messed with anything recently i wouldnt worry about that...
Old May 12, 2008 | 11:34 PM
Hexxum001's Avatar
Has it rained in your area or have you washed your G recently?? I had this problem after heavy rains earlier this year here in SoCal. Moisture got into my ignition system and blew 2 coil packs on my passenger side. I got the P0300 code btw.
Old May 13, 2008 | 01:03 AM
im going to have to get an scanner read again and check the code i will post the code as soon as possible thanks to all of you for your tips which hey hexxum did your car run abnormal when the 2 coil packs were blown? and i wash my car with the water running on the car not at it...and i dont drive the car for a couple of hours after washing it.... but yea i will scan again here in the next couple of days...
Old May 21, 2008 | 09:24 PM
amoreno35's Avatar
my car is running fine but my service engine light came on.. i took it to autozone and i got the P0300 code.. so wut do i need to change???
Old Jun 16, 2008 | 04:01 AM
its random cylinder misfire...i tried changing the spark plugs and still that damn code pops up
Terry_G35
May 9, 2020 01:39 AM
Terry_G35
Aug 4, 2015 02:38 PM
