Help With UR Cranks Pulley Belt Sizes
Old Apr 21, 2004 | 02:02 PM
SixFive's Avatar
The UR instructions say 45.25" for water pump and 35.875" for the AC. THis is for a Z install tho
I also read here somewhere that 44.5 for water pump and 35.0 for AC.
Is this discprepency due to the G having different belt geometry than the Z? Gsedanman you out there?
2003.5 DP Sedan (Everything but Nav)
Injen CAI
10 Wire Hyper-Ground
Polk Tweeter Upgrade (EX-3500)
Crawford Plenum (V4)
H-Liner Sound Deadening
Shock Sensor
UR Crank Pulley
Old Apr 21, 2004 | 02:39 PM
Ed_C's Avatar
Re: Help With UR Cranks Pulley Belt Sizes
Chris, does this mean thst the Goodyear belts are incorrect in size/
Ed C
Old Apr 21, 2004 | 03:35 PM
SixFive's Avatar
I was on the phone with UR just now and he says if you can get it on its not to small and didn't seem to think the goodyears would be a problem. Length doesn't matter if you can get it on and get it on tight enough. (LOL) I'm wondering why it looks ruff on that one edge - it may be that it got cut a little when it was initially rolled into the rail...
Injen CAI
Shock Sensor
UR Crank Pulley
Old Apr 21, 2004 | 08:20 PM
hotg35's Avatar
Glad I ordered mine from a vendor that will only sell the pulley with the correct belt. Why sell it without it, you have to have it.
Old Apr 22, 2004 | 08:22 AM
SixFive's Avatar
What i've said is that the belts are ok size wise. I got the info from this site so which i consider more reliable than the vendor perhaps and it turns out to be good info.
Injen CAI
Shock Sensor
UR Crank Pulley
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
MR M37s
Oct 30, 2015 08:32 AM
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
linedr89
Aug 17, 2015 05:11 PM
