Help! Oil filter won't budge
Old Apr 23, 2004 | 02:53 PM
skaline's Avatar
I've always changed my own oil. But this time the fricking soda can of a filter won't budge. I have pretty much crushed it like the little soda can that it is. I've tried every wrench I have, even my bare hands. Won't move a hair. WTF?
Old Apr 23, 2004 | 02:55 PM
al503's Avatar
Re: Help! Oil filter won't budge
if the very end of the filter is still in decent shape, i would get the little caps that you can use with a socket wrench. If not, you might just have to punch or drill a hole in the filter, stick a screwdriver in there and twist it off that way.
Old Apr 23, 2004 | 03:28 PM
skaline's Avatar
I've got one of those caps to use with the socket wrench. It just spins around. I guess I need to get a metal one because the plastic one I have seems to flex too much. I used one of those gripper wrenches with the rubber strap and got it off that way. I thought about punching a hole and using a screwdriver, but I really didn't want to do that. Thanks for your help.
Old Apr 23, 2004 | 03:31 PM
Grantw35's Avatar
This way is messy, BUT it will work. Take a extra long screwdriver and drive it right through the (oil) filter. The screwdriver should go from one side through the other side without hitting the bolt the filter is screwed onto. Leave enough room to torque the filter a quarter to half revolution. Make sure you don't go right in the middle of the filter and hit the bolt the filter screws onto! When it breaks loose pull the screwdriver out and then just use your hand to unscrew it the rest of the way.
Good Luck!
2004 Infiniti G35 Coupe Ivory Pearl/5AT/aero/premium/nav/performance
Old Apr 23, 2004 | 03:40 PM
Z06ified's Avatar
Yes, the screwdriver method works well. Messy, but it works.
2003 G35C, 6MT, DG/G, Aero/Nav/Premium
2002 Corvette Z06, Electron Blue/Black
Old Apr 23, 2004 | 03:57 PM
Msedanman's Avatar
O.F. Administrator
I've had the same issue over the years so I do this now and it works great.
I get a wrench to fit, and glue (contact cement) some rubber (inner-tube) on the inside to grip the filter. -- See pic.
The filters are supposed to go on 2/3 of a turn after the gasket contacts, but it usually tightens up a lot and makes removal difficult.
I've not had any more problems with tight filter removal.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Apr 23, 2004 | 04:37 PM
tonke73's Avatar
No, No, No, Use a monkey wrench bro. There is plenty of clearance to get one of those bad boys in there. It is much cleaner than the poking the hole through the filter. I've done that before on my last car. Cleanup was not fun.
Old Apr 23, 2004 | 11:20 PM
AirWarrior's Avatar
BUT JUST REMEMBER:
"RIGHTY TIGHTY, LEFTY LOOSEY"
... just in case you were going the wrong way
Old Apr 23, 2004 | 11:41 PM
ZtoG's Avatar
Channellock pliers, works everytime.
04' Desert Platinum 6MTCoupe
72' 240z,turbo,intercooled,Electromotive TEC2
Old Apr 24, 2004 | 01:05 PM
GeeMan's Avatar
Best advice yet.
03.5 5AT-S (Black-Willow-Premium-Sport-Aero-GroundingGear™-Silverstars-PIAA-PopCharger-Z Tube-Tint)
Old Apr 25, 2004 | 11:36 AM
waijai's Avatar
i.love.gold
I was having some trouble this past weekend when changing my oil. I used a sheet of sandpaper wrapped around the filter, and it gave enough grip to turn the thing off.
Ivory Pearl coupe
Old Apr 25, 2004 | 12:22 PM
Rob_G35's Avatar
In Search of Magic
SCREWDRIVER BABY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
03 CB Coupe 6MT
www.itclan.com/g35
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
DRG35R
Sep 16, 2015 05:33 AM
ben_m
Engine - Intake/Fuel
Sep 7, 2015 10:04 PM
JG_G35
Sep 7, 2015 09:35 PM
UT G35
Sep 3, 2015 03:58 PM
