AC Problems.. Help...2 big a$s pictures
Old Jun 29, 2008 | 01:56 AM
MixturePinoy's Avatar
Today I attempted to recharge my AC. during my inspection of the AC routing, I noticed something pretty bad... It looks like a part of my cheapo ebay intake has been knocking or some how melted into the High AC tube. I'm wondering how difficult it is to replace? Or, is there a way that I could mend the wound... BTW.. I will be going back to OEM intake ASAP.
Okay.. i was kidding about the pictures
Old Jun 29, 2008 | 04:50 AM
Meatshackle's Avatar
Deep Sea Moderator
That's a common problem with aftermarket intakes. You have to be real careful how the flange is positioned. You should be fine as long as it's holding and hasn't rubbed all the way through.
I had to replace mine a few years ago, not cheap at all. That ac line runs all the way across the engine bay along the firewall.
Old Jun 29, 2008 | 05:18 AM
OCG35's Avatar
most people will tell you its this:
https://g35driver.com/forums/intake-exhaust/90906-installed-jwt-pop-charger-protect-move-ac-line.html
I think it's the green intake tube.
Old Jun 30, 2008 | 12:03 PM
Anyone know a way to patch it up? I was thinking cutting tubing and coupling or welding it in place?
Old Jun 30, 2008 | 12:14 PM
OCG35's Avatar
if it rubbed all the way through, I think its fubar'd dude... from the pics its looks like it hasn’t gone through... I'd just replace, or re-position the intake and wrap the line at the previous contact point and keep an eye on it...
Your AC works right? and it held the charge?...
Old Jun 30, 2008 | 01:53 PM
it actually went through to the hollow point and is not holding a charge at all.
Old Jun 30, 2008 | 02:43 PM
falconey's Avatar
ouch, the few that I've seen with this problem had to replace the line.
Old Jun 30, 2008 | 02:55 PM
Well, I just called a salvage yard and they had the tubing for 40 bucks. i'm just wondering how difficult it would be to DIY it now.
Old Jun 30, 2008 | 03:07 PM
Deep Sea Moderator
Jump on that $40 deal. I think I paid $200.
Old Jun 30, 2008 | 07:03 PM
superchargedg's Avatar
Once you replace it dont try and recharge it cause air and r134 dont play nice together.You will have to have the system put on a vacumn and then recharged.
Old Jun 30, 2008 | 07:38 PM
CreativeDesignZ's Avatar
i put some silicone vacuum line around that bad boy, no rubbing issues at all
Old Jun 30, 2008 | 08:19 PM
OCG35's Avatar
ooops... from what I've heard its not easy or cheap... good luck.
I need to check on mine
Old Jul 1, 2008 | 11:29 AM
Thanks for the info. I'm picking up the piping today and I guess I have to take it to a shop for the AC work. BTW, what kind of issues would i be looking at if i do not connect it to a vacumn?
Old Jul 1, 2008 | 06:34 PM
When you open the ac system of course air gets into the system and as freon is a gas like oxygen one gas cannot just replace another gas(no room).You have to put the system under a vacumn to remove any air in the system and then you can recharge the ac system.
Also it is advisable to replace the accumulator as it is a part that absorbs water from the ac system to stop internal corrosion of the ac parts.
jilljann1
Jul 21, 2020 08:12 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
ChrisAult2004
Sep 11, 2015 10:33 PM
NJ6MT
Sep 10, 2015 08:40 AM
