Before/After Mod Info
Old Jul 28, 2008 | 10:51 PM
  #31
trey.hutcheson's Avatar
Are you just looking for something that will totally disable vdc and enable standing burnouts?
I don't know what it takes on an 04 5AT, but I can disable my vdc in under 3 minutes at the track.
Old Jul 29, 2008 | 01:55 AM
  #32
DaveB's Avatar
OCG35- Have you tried disconnecting the yaw sensor under the drink holder of the center console? On my G, it turns off the VDC and traction control. The launch feels stronger, but I really can't know until I go to the strip. I may go to the strip here in a week or so in the dead of summer because I've got so many little things I want to try at the strip that I don't think I can wait until October I know I'll be slow, but how much slower.
Old Jul 29, 2008 | 12:49 PM
  #33
OCG35's Avatar
I’ve never had VDC kick in and hinder – not to the extent of applying brake like it does on streets when I leave it on… however I guess it might address the brief power cut.
Y interest is not for standing burnouts… it’s to do 2K-2500 rmp launch – which in an AT we can only do by applying brake and throttle at same time (brake torque)…. I’ve though about doing the grey box plug near brake fluid reservoir – but I was so sure that a module would be developed that I never bothered with other methods… I guess I need to re-visit.
Old Jul 29, 2008 | 12:56 PM
  #34
OCG35's Avatar
I've considered it - but like I mentioned in response to Trey - I thought I had a built it fix on its way...
My only concern/dissuasion from the yaw sensor is I don't like removing interior pieces too often... the fit & finish isn’t very good to start with... some of the things that have been removed for other projects end up causing more rattles... Its not important enough to me to risk more vibrations and rattles.
If I don’t end up with a module, I’ll probably try one of the methods you and Trey mentioned (I know they are old tricks, I’ve been aware of them for quite some time)…
There is another factor though that I always like to consider – I like to run at the track just as I would on the streets… sometimes I don’t even take mats, spare and jack out… But I do need the option of finding the best ET so I will give some of the mentioned methods a shot at some point.
Old Dec 12, 2008 | 10:23 PM
  #35
psedog's Avatar
Back in SD**
What? Do you drive the same car I do?
My car dyno'd 241/210 stock. After a stillen airbox, motordyne 5/16 spacer, mrev+ lower plenum, ichiba headers, kinetic resonated test pipes, stillen exhaust, utec with a tune, ngk iridium spark plugs, jtw flywheel, and a custom oil catch can, I dyno'd 265/250.
"alot more than 30hp" - that's funny.
No, he doesn't have the same car. You have a 297hp 5MT and he has the 280 5AT
Old Dec 13, 2008 | 04:04 AM
  #36
OCG35's Avatar
hmmmmmm.......... you mean he doesnt have a DE???...
Old Dec 13, 2008 | 04:27 AM
  #37
OCG35's Avatar
psedog! Thanks for reviving this thread!!! Not because of the reference post above, but because it made me re-read previous posts...
To all that have read (and are following) any of my brake torque posts... I have data logged ECU drag strip function off idle and brake torque... it is well over 20 seconds of detailed data to analyze - and admittedly I haven’t spent the time required to determine everything - however, I looked at enough to know I'm not imagining things... the details are being evaluated by UpRev...
I'm not certain I was able to log all that’s needed for an absolute - our 1/4 track doesn’t provide many runs... I have offered UpRev a bunch of launches at local 1/8 mile track that provides 8-10 runes per night (and without the subconscious pressure of 1/4 mile showmanship)... if what few runs I gave from ¼ mile isn’t enough, I’ll give more.
I'll let UpRev announce any "fix" to the problem.
BTW - they suspected the "problem" and had viable reason to know it exists before my logs being sent (not just from my concerns) - they are using my data logs to isolate and confirm what is suspected.
To those that haven’t realized it's an issue... stand by - when the fix is in you'll probably agree/admit it’s a problem (like so many things in life).
Charchar66
Dec 19, 2019 01:17 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Rose M
Oct 12, 2015 10:00 AM
RWDguy4238
Sep 30, 2015 12:13 AM
