Is racing Fuel Good or Bad for our G35
Old Aug 12, 2008 | 05:45 AM
jebus2006G35's Avatar
Question Is racing Fuel Good or Bad for our G35
Hey guys I reading other post but I still Didn't find what I was looking for. Well I have heard so many good things about Racing fuel but I wanted to know if its good for our car. I don't race so its not like i am going to be putting it all the time. Just wanted to try it once in a while. I live in Los Angeles so there is a couple of gas stations that have 100 Octane. 100 Octane is the one that I have heard that my people use lot but my question is, what about using 108,114 or even 121 Octane? Will it damage my Engine? I know its expensive but what do you guys think? What is your feedback for guys that have used it? Thanks lot.
Old Aug 12, 2008 | 09:39 AM
dofu's Avatar
20 Year Member
Here's a better question: Why???
Even 100 octane would be a bit excessive without being tuned for it, and 121... don't know what to tell you...
Old Aug 12, 2008 | 09:40 AM
express705's Avatar
help i blew my motor!!! leaded gas FTL
Old Aug 12, 2008 | 09:51 AM
Hi-TechG35's Avatar
^LMFAO...only Mike...
Old Aug 12, 2008 | 10:05 AM
GreenGoblin's Avatar
The goblin resurrection
Mike lets get the airboat gas in weston?????
Old Aug 12, 2008 | 10:10 AM
express705's Avatar
2030549354 octane airboat gas!!!!
my cessna runs on that ****.
Old Aug 12, 2008 | 10:11 AM
Audible Mayhem's Avatar
race gas is where its at...
only if you tune for it.
Old Aug 12, 2008 | 10:12 AM
express705's Avatar
jerimiah was a bullfroggggggggggggg
Old Aug 12, 2008 | 11:39 AM
adamhoud's Avatar
+1....its not like putting some magical HP adding solution in your car, no gain without tune.
Old Aug 12, 2008 | 01:32 PM
silver g's Avatar
Why would you want to spend even more money on something that you really do not need? Gas cost enough as it is. 91 Octane is fine for what you do, and without a tune anything over that will not do much for ya.
Old Aug 12, 2008 | 01:38 PM
im happy with my 93
Old Aug 12, 2008 | 01:45 PM
BolivianFuego's Avatar
There is no need for race gas or anything higher than 93 unless your boosted or have high compression'd all motor race motor. You could get the max power out of these setups with higher octane fuel running more agressive timing.
Old Aug 12, 2008 | 02:15 PM
htownboy's Avatar
+1 You will get very little benefit from anything over 93 as the machine is tuned from Japan for 91 unless you start custom tuning\modding.
Old Aug 12, 2008 | 02:27 PM
wyldfyer's Avatar
Its funny how people would rather poke fun then lend valuable info. I didnt realize that so many nerds drove such a hot car...weird, LOL.
Honestly, maybe you should just put Super in there and mix it with 100 or try an Octane booster.
The higher the Octane rating, the faster the gas will ignite which in general is good. However if it ignites too fast or at the wrong part of your engine cycle, you'll get potential knocking and your car will perform badly...or worse!
If you want to run that other stuff, you have to increase your compression ratio. Octane rating has a direct correlation to compression ratio. Thats why we have to use Super (even though you can get away with plus...maybe..but I wouldnt).
Old Aug 12, 2008 | 02:58 PM
Actually! Since from the factory the car probably was made for 91(cali) the ECU has perfect timing and fuel tuning for that octane, throwing in some higher octane messes with the tune and is probably taking away from the power you are making.
So no, adding in higher octane gas will actually, HURT your power.
