APS cooling oil pan is only $100 bucks now?
Old Aug 16, 2008 | 11:18 PM
EvolutionGSR's Avatar
http://www.importpartspro.com/apshicaoilpa1.html
http://www.z1motorsports.com/350_g35...oducts_id=2131
Ok...i used to see this for $400, is there something I'm missing about why these are so cheap now?
Old Aug 17, 2008 | 02:41 AM
OCG35's Avatar
because they aren't worth $400
Old Aug 17, 2008 | 02:56 AM
Ha. I did a little searching and people have been complainging about the drain plug stripping the threads off the pan easily. I might just do a aam or jwt spacer.
Old Aug 17, 2008 | 06:46 PM
rpm06g35's Avatar
those pans arent really worth it. plus they hang way low here is what we in sfl have done.
10an fittings welded on the inside
you will need allen head bolts to clear the fittings
then just add a remote oil cooler and your set
junkyard cooler I bought for 40 bucks later guys mike
jsimonk
Dec 22, 2023 03:49 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
itztwinki3
Aug 11, 2015 05:52 AM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
