any N/A mods that do give decent gains to our G?
Old Sep 16, 2008 | 07:57 PM
OCG35's Avatar
Originally Posted by DangerMouse
If you are serious about tuning your car, find a shop that will sell you a package of dyno runs (schedule as needed) and use them after each "makes a difference" modification. Also ensure that your car is in good condition to begin with.
Too many people jump into this game without basic maintenance, and exit early with a broken (driveline/engine/wallet).
My 2004 X picked up 12-15wtq over baseline with this package:
* Motordyne 5/16" copper iso thermal spacer
* UpRev e-tune (send in your AFR logs after each mod)
* HKS Sport muffler
* Blitz SUS power filter (stock size, stock box)
Best run to date: 250.2whp, 262.8wtq
Worst case for performance (20% AWD driveline loss) gives 300hp/315ft-lbs at the crank. Best case (25% loss) gives 312hp/328ft-lbs at the crank.
And for an $18k (used) AWD sedan with $2k of modifications, those gains are not bad at all. I recently worked with UpRev to tweak the maps.. probably due for another dyno run soon.
Exhaust (HFC, etc) is one of the last modifications to make to the VQ in my opinion. These are not high-compression FI systems with too much backpressure looking for a new home. Buy a nice sounding muffler (hard to go wrong with HKS) if you want sound.
- DM
I'm sorry, but much of this is wrong too... nothing being discussed (especially in you post) will break your driveline or motor... and I'm not sure where you get your info about HFC but it is a very worth while mod.
Old Sep 17, 2008 | 01:51 PM
adamhoud's Avatar
+1, IMO HFC will give the majority of exhaust gains.
Old Sep 17, 2008 | 02:02 PM
Klubbheads's Avatar
Originally Posted by SDGeneralCounsel
NA mods on the vq do nothing
except shave 0.5-0.7 off ur 1/4 mile time for a 6MT and over full 1 second on the auto that puts u in 335/E46 M3/E550/CLS550 category.
Old Sep 17, 2008 | 02:08 PM
Skaterbasist's Avatar
Retired SuperMod
As usual, this is a false statement. I can actually speak from experience
The gains for $$$ aren't the best, but to say it does nothing on the VQ is definately not true.
Old Sep 17, 2008 | 02:45 PM
OCG35's Avatar
notice how the people that actually go to the track and have dyno'd, respond with reality and those that have probably never taken their car to the track or been 100+ or been on a dyno report flase statements
Old Sep 17, 2008 | 09:33 PM
maxspeed96ct's Avatar
cool so should i get the hfc or not bother?
I bought the intake and the spacer and read some bad reviews..
im almost giving up on modding it ..
also im at 8k still, what milage does the vq break in at?
my buddie told me my car wil get way faster after break in.......
Old Sep 17, 2008 | 10:07 PM
SDGenius's Avatar
Originally Posted by OCG35
this is wrong. HFC give great low to mid trq (a/f must be adjusted for max gains).
oops, my bad... thanks for the correction
Old Sep 17, 2008 | 10:58 PM
DangerMouse's Avatar
Never said that, chief. I've seen dozens of modified cars (especially imports) with every possible aftermarket mod but fouled plugs, a leaking head/rear main gasket, and differential fluid that looks like mud. Combine that with some yo-yo beating on their newly modified car, and it's a recipe for something major to break loose at high speeds.. just make sure the basics are covered before you start adding on mods.
Just an observation from over 20 years of personal experience building and modifying both N/A and F/I (both roots blown s/c and turbo) cars. On most setups, you don't really appreciate an HFC at low pressure unless the stock design is overly restrictive. And based on what I just read about noise levels after adding an FI HFC (http://www.6mt.net/forum/g35-coupe/2...tions-hfc.html) that might be true.
Do you have a link to a before/after dyno without someone monkeying with the fuel maps in the middle? Difficult to see what effect the HFC had versus "other mods" in most of the dyno posts I've read here.
-DM
Old Sep 18, 2008 | 12:39 AM
AARONHL's Avatar
What's involved in a "TUNE"?
Old Sep 18, 2008 | 06:32 AM
OCG35's Avatar
-DM
you need to re-read you post that I replied to - and re-evaluate the HFC application we are referencing.
Old Sep 18, 2008 | 07:57 AM
making the perfect air/ fuel ratio.
I assume after putting high flow cats and other intake exhaust mods it makes the car run rich . SO tunning must help ? right?
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
paniaguag35
Jul 29, 2015 12:05 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
