Loud screeching noise
Old Oct 1, 2008 | 09:55 AM
RaginRaj11's Avatar
This morning i started my car and let it sit for about 5 minutes. I put the car in reverse and i heard a loud screeching noise coming from the engine bay. I put it in park and turned the car off and on again and the sound is gone. Anyone know what it could've been?
Old Oct 1, 2008 | 12:29 PM
Deezflip's Avatar
probably one of the belts...have you changed your belts recently? I've had some random screeching noises on start up ever since I've replaced my belts, especially when I have the A/C on start up.
My guess is, it's either too loose, or too tight. I've been trying to dial in the right tension, but it's hard to do so when it only screeches like once every 2 months, not to mention those 10 millions bolts to remove the lower cover.
Old Oct 1, 2008 | 12:34 PM
express705's Avatar
you dont need to remove the lower cover to adjust the belts.
Old Oct 1, 2008 | 05:12 PM
RaginRaj11's Avatar
i had the belts and a bearing replaced a couple months ago.
Old Oct 3, 2008 | 11:20 AM
sliderg35's Avatar
I'd like to see that!
Old Jan 29, 2009 | 11:57 PM
AARONHL's Avatar
Why does my car still screech after I've replaced the belt, tensioner, and alternator? Anyone have a fix?
Old Feb 4, 2009 | 01:59 PM
Deezflip's Avatar
I went to tightened one of the belts this past sunday while I changed my oil.
I gave both belts a finger check and guessed that the skinnier belt of the two could use a little more tension. I'm assuming that some of these belts has a break-in period causing it to stretch and loosen up a bit. The thicker belt seemed ok so I left that alone. So far so good, no squeals. Then again, it's only been about 3 days. We'll see...
Old Feb 4, 2009 | 02:34 PM
AARONHL's Avatar
I also tightened the belt and the noise went away. I can turn it about 45 degrees now, before I could turn in 90 degrees. I guess the problem was I just didn't tighten it enough. The G35 belts love to be TIGHT...
I basically replaced parts that didn't need to be replaced. Anyone need a belt tensioner pulley, alternator, and/or belt?
Old Feb 10, 2009 | 10:42 AM
MetalCow's Avatar
speaking of belts, will these work
http://www.mynismo.com/products/?id=4325
I need to replace mine
Old Feb 10, 2009 | 11:54 AM
Deezflip's Avatar
not unless you have UR pulleys...those belts are different lengths to compensate the different size of the underdrive pulleys from the OEM pulleys.
Old Feb 12, 2009 | 12:05 AM
G35Sask's Avatar
I'd also like further explanation on this one..... That would be great if I didn't have to pull 30 bolts.
Do you have to loosen the pulleys to tighten the belts or just tighten the adjustment bolts?
Old Feb 12, 2009 | 12:36 AM
Deezflip's Avatar
yes, you have to loosen the pulleys. It acts like a lock once you dial in the right tension.
With that said...for each belt, one bolt(pulley) to unlock/loosen it...and then one bolt(usually on a bracket) to crank it up and down to adjust the tension.
Old Feb 12, 2009 | 12:45 AM
G35Sask's Avatar
That's what I thought, thanks a lot. I replaced both my belts tonight and they are a bit loose, nice squeal on start and for a few blocks after at 2000+ rpm. I guess I'll have to break down and rip that retarded 30 bolt cover off again and tighten.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
3000vr4tt
Sep 7, 2015 12:48 AM
