no low end torque!
Old May 20, 2004 | 01:23 PM
artmansr's Avatar
no low end torque!
I've been playing with the car, trying to see what it can do! noticed that the low end speeds are not all that good. I got the pop charger, z tube, u/r pulley and 3.5" y pipe. can't seem to make the tires bark...i do have the vdc off. I've tried using the manual shift and same results. i've also reset the ecu... any pointers would be appreciated....
Old May 20, 2004 | 01:47 PM
BrianV's Avatar
Re: no low end torque!
The combination of your mods has most likely caused a reduction in low-end power. On the other hand I'm sure your car is FASTER.
04 6MT Sedan - Z Tube, 04 Z Suspension
Old May 20, 2004 | 01:55 PM
BigRon's Avatar
3.5" Y pipe?! Doesn't that seem a little big? For a NA engine, unless you're producing gobs of power, 2.5" or so should be ideal.
You don't often find pipes larger than 3" for turbo cars!
That would certainly rob you of some low-end TQ, even with the back-pressure of stock pipes and cats. But as was mentioned above, I'm sure your top-end HP is higher.
Future G35C Owner... ...Never too soon to think about modifications!!
Old May 20, 2004 | 01:58 PM
BrianV's Avatar
Yeah I missed the 3.5" part, definitely large.
Old May 20, 2004 | 02:24 PM
Catatafish's Avatar
Brake until about 2000-2200, that should do the trick. I did that on a 55 degree day on asphalt county road and I spun em. It also cost me .5 seconds on the 1/4 mile, wear on my tires and wear on my tranny. I got much better times with VDC on.
2004.5 Coupe/5AT/Ivory/Everything but chin spoiler/Z Tube-Popcharger/Crawford V5 Plenum on the way
Old May 20, 2004 | 03:15 PM
Gmaster's Avatar
No low-end torque? Yep, your custom Y-pipe is the cause plus stock ECU confused.
1. Get Stillen full exhaust
2. Get Technosquare Inc. ECU reflash.
'04 G35/5AT sedan Silver/Black
DYNO: 209.2whp@209.4wtq (bone stock)
Old May 20, 2004 | 03:26 PM
artmansr's Avatar
thanks for the replies:
i just got off the phone with Kinney's muffler shop and i misinformed you guys. it's a 2.5" y to a 3" single. would that still cause the low end issue i'm inquiring about? thanks again. to all of you.
Old May 20, 2004 | 04:47 PM
BobbyD's Avatar
The power curve of the G35 doesn't get going till over 3000 rpms! With an aftermarket torque converter you could be in the powerband a lot sooner. Another option is changing to lower rear gears(numerically higher) in the differential.
When I ordered my 6MT I discovered it comes with an adjustable torque converter, the driver![img]/w3timages/icons/laugh.gif[/img]
2003 G35 Sedan 6MT
14.13 @ 99.55 (stock)
Old May 20, 2004 | 04:53 PM
BigRon's Avatar
3" exhaust pipe for an NA engine is still a little big, IMO. Like I said, 3" is typical for turbos, where there's no such thing as going too big. I'm not sure how much of a loss that would translate to on the low-end.
I'm not sure what the industry standard is on exhaust for the G35 right now. Could be everyone is making larger diameters so that the same system will work on a turbosharged G, but that would likely be at the sacrifice of a serious low-end loss on the stock G.
After hearing the diameters of most of the aftermarket exhausts, that should answer your question. Maybe others will let you know what size they're running or you could check with the different aftermarket companies to see what size they're using.
Old May 20, 2004 | 06:03 PM
DED's Avatar
DED
Drive a Honda for week and then go out and kiss your tailpipes.
2004 G35C 6MT Black. I stare. And I am content.
Old May 20, 2004 | 06:48 PM
neffster's Avatar
...and if the neighbors see you, tell them it's none of their business.
300bhp??? We'll see... 5-22-2004
Old May 20, 2004 | 08:47 PM
GurgenPB's Avatar
LOL neffster...
Anyway, to the topic...3" is absurdly much for an N/A car. There is absolutely such a thing as too big an exaust for an N/a car. You need to maintain gas velocity to keep your low end. Of course your top end is very strong, but how much of a sacrifice are you trying to make...
I noticed a huge drop in my low end performance after installing the RT cats...
Gurgen
Old May 20, 2004 | 08:52 PM
havok5414's Avatar
What if one was only to install less restricting cats, but keep the rest of the exhaust stock. Would you still loose the low end torque.
Inside my shell, I wait and bleed
2003.5 Black/Black 5AT Fully Loaded w/ Navi
Clear Corners / Injen CAI
Old May 20, 2004 | 08:56 PM
GurgenPB's Avatar
no try the other way around... Much more benefit to be had from an exhast upgrade vs. cat upgrade
urgen
Old May 20, 2004 | 09:11 PM
Buddha's Avatar
yea, the exhuast would be restricting the free flowing cats. Replace both I guess.
04 G35C 6mt/aero kit/nav/premium
