here are pics of engine mods
Old Mar 16, 2003 | 05:27 AM
alexthekurrupt's Avatar
i have my grounding kit installed and yes it is the jdm grounding kit from nissan not home made. also the blitz air filter and nismo radiator cap. ( the radiator cap does not add horse power it is just for show)
Old Mar 16, 2003 | 05:30 AM
Re: here are pics of engine mods
more pics
Old Mar 16, 2003 | 05:32 AM
and some more
Old Mar 16, 2003 | 05:35 AM
oh and here is what the jdm clear corners look like on a black coupe
Old Mar 16, 2003 | 08:55 AM
BillR's Avatar
Can you post the Nissan grounding kit instructions?
I think the mounting points are different from Insaneamine's kit, and I would like to see the diff.
OR
post pics of the mounting locations.
Thanks!!!
BillR
G35C Laser Red, Prem, Nav
Old Mar 16, 2003 | 09:19 AM
silverg35's Avatar
Where did you get the kit? I want the silver grounding kit for my G but I've only seen gold on japanparts. Also, how much did you pay? It looks very nice.
Thanks
Ryan
Old Mar 16, 2003 | 01:12 PM
dspisak's Avatar
Where did you get the two-tone engine cover? My 2003.5 has an all black cover.
Can someone tell me why a gounding kit is needed? On my G35S I measured less than 0.1 ohm from the top of the intake plenum to the negative terminal of the battery. From the throttle body to the negative terminal of the battery measured 0.0 ohms. I installed 4 gage cables from the intake plenum to the grounding lug on the front timing case and from that grounding lug to the negative battery lug. There was no change in resistances. There was no noticable change in noise, vibration, or idle speed. The mechanics in the engine lab at work say that resistance would be a concern only above 3-4 ohms. Does anyone have any data? So far, adding a grounding kit sounds like adding Christmas ornaments.
<font color=blue>Dan</font color=blue>
Old Mar 16, 2003 | 01:27 PM
OvaYahead's Avatar
billR,, I've seen Alex's car in person and studied the grounding kit. Yes it is different. It has 6 cables instead of 5, different connection points. I don't know if you'll notice a difference in the car, but the system was designed by Nissan.
BS G35C 6spd navi/aero/prem
Old Mar 16, 2003 | 03:14 PM
pestilence's Avatar
dspisak: the two tone engine cover comes with coupes.. the sedans have the all black cover..
..pestilence..
Old Mar 17, 2003 | 10:33 AM
dspisak's Avatar
Snazzy!!
Old Mar 17, 2003 | 11:43 AM
OvaYahead's Avatar
did you see the black and blue one in the japanese v35?
Old Mar 17, 2003 | 12:55 PM
99atlantic's Avatar
pardon my stupidity, but what does grounding do anyways??
www.ironpumping.com
^^Bodybuilding Made Simple
Old Mar 17, 2003 | 03:24 PM
dspisak's Avatar
I agree. One would think that a 0.5% HP increase would be lost in the "noise" of changes in temperature, humidity, air pressure, the dyno itself, etc.
In addition to the placebo effect there is also the seduction of "high tech".
