Oil Leak
Old Oct 20, 2008 | 08:54 PM
SDGeneralCounsel's Avatar
Originally Posted by g35at
i recently had my spark plugs replaced and the mechanic told me that my valve cover gasket was leaking and needed to be replaced. i was quoted about 180 in labor and 40 for the part. im aware that the part is overpriced, am i messing up my new spark plugs the longer i wait to replace the cover gasket?
thanks.
I think I paid 30 for my gasket. 40 is not that overpriced once you factor in shipping and whatever profit margin your shop has to make.
Old Oct 20, 2008 | 09:09 PM
bythabay's Avatar
Originally Posted by NismoG35S
sigh cant belive no1 has said anything about that valve cover gasket.. its the circle seals that seal the spark plug tubes that are leaking not the actual vc gasket to the cylinder head.. other wise u would have oil on ur engine and not on your spark plugs.. the circle seals only come witih new valve covers. infiniti price arnd 850ish if i remember correctly. replacing the outer valve cover gasket will fix nothing in your case. as far as the coil packs go i dont think any damage can come to them. all thats down that far is a conductive spring and the plastic+rubber tube.
+1
Spark plug tube seals need to be replaced and only come with new valve covers. I know Toyota sells these seals separately for their v6 engines.. would be interesting to see if we can substitute their spark plug tube seals in place of ours...
I know their differential and trans aluminum washers are a direct replacement for the ones that Nissan sells AND they're less than half the price
Old Oct 23, 2008 | 11:17 PM
coup de grace's Avatar
My leak wasn't as bad as I thought it was, I had the valve cover gaskets replaced and the tube seals sealed up with silicone. The coilpacks were cleaned and reused no problem.
So far so good.
Old Oct 24, 2008 | 10:28 AM
canucklehead's Avatar
wouldn't this be considered a warranty repair?
Old Oct 24, 2008 | 11:29 AM
Boston's Avatar
+1 and the leak is a common problem. I only have it on one cylinder but it has no affect on the spark plug or coil pack for that cylinder. I just just a small pool of oil in that socket.
Old Oct 29, 2008 | 09:49 AM
waijai's Avatar
i.love.gold
Has anyone every bought brand new valve covers to see new spark plug tube seals?
Old Jun 30, 2010 | 09:45 PM
fatlip's Avatar
Im thinking u might be able to reseal the plug gaskets if u can get creative with 3m 5200 sealant. That **** is super badass marine sealant. Just a thought.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
mbe32
Nov 13, 2015 11:09 PM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
vamarris
Sep 26, 2015 12:56 PM
