Rack and Pinion parts relate to Strut and Sway bar??
Old Oct 22, 2008 | 12:09 PM
Preston's Avatar
Hey G35 drivers,
One of Infiniti dealer trying to make non-sense case with me so they can avoid my warranty work. I want to make case against them so I can obtain proper repair.
They claiming that rack and pinion damage is relate to aftermarket spring, strut, and sway bar. Is that true? My car had dropped barely 1/4" inch using H tech spring and to my understanding, r&p has nothing to do with suspension work, I mean r&p is mainly for turning front wheels?
Pls advise your thought
Thanks
Pres
Old Oct 22, 2008 | 12:11 PM
GreenGoblin's Avatar
The goblin resurrection
depends what is the issue you are having with your rack and pinion
Old Oct 22, 2008 | 12:17 PM
Preston's Avatar
Oh, I left that out. Well, last week I installed Stillen sway bar w/ Suspension technique bushing. Well, after install I started to hear "tump" sound on the uneven road, so I took it to the shop and this guy tells me that right side of bushing feel loose, so he added extra black rubber layer inside of S/T bushing to make it tighter. After that, I now hear metal "creak" or should I say clinking noise everytime I go over the bumps in low speed. I figure this extra layer is the cause of the issue, so I took it back to him and he started to saying that noise is cause from my rack and pinion. What do you think?
jsimonk
Dec 22, 2023 03:49 PM
Luisgalvan33
Jul 19, 2018 08:16 PM
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
