Oil Change
Old Mar 17, 2003 | 04:41 PM
G35Maine's Avatar
Oil Change
My dealer says oil changes are only required every 7,500. The manual says 3,750, but leaves it open for 7,500. Any advice?
Old Mar 17, 2003 | 04:43 PM
stewa101's Avatar
Re: Oil Change
It all depends on how you drive the car. If you drive a lot on surface streets, it's probably a better idea to change at 3750. If you drive mostly on the highway, you can wait til 7K.
Andrew
2003 coupe 6MT blue premium aero (since 3/9/03)
Old Mar 17, 2003 | 05:08 PM
ryoken's Avatar
Re: Oil Change
The manual has a list of criteria in that section that you can look at and compare your driving habits to, to decide which route to go.
Old Mar 17, 2003 | 05:09 PM
stewa101's Avatar
Re: Oil Change
Yep, and you can always try somewhere in between.
Andrew
Old Mar 17, 2003 | 05:36 PM
ryoken's Avatar
Re: Oil Change
And then there's the whole issue of switching to synthetic....
Old Mar 17, 2003 | 05:46 PM
stewa101's Avatar
Re: Oil Change
Oh no, we're breakign the post wide open again [img]/w3timages/icons/wink.gif[/img]
Andrew
Old Mar 17, 2003 | 05:48 PM
GBech's Avatar
Re: Oil Change
According to the manufacturer-
Oil changes are every 3750 for the sedan and 7500 for the coupe according to the documentation. The technical jargon that came with this was that the expected "optimum performance" motor life (Motor operation with no performance loss, compression, HP, etc) of the sedan was 150K and the coupe 100K based on following the recommended "regular maintenance" cycle.
I have had my done on the recommended sedan cycle of every 3750 miles based on the recommendation of the service manager. The only real shock came at the 7500 mile mark when the routine service (tire roation..blah..blah) ran $168.00.
$39 for an oil change was OK, but $168 for the 7500 service even if they do inspect the brakes ,rotate the tires, and give tire life measurements.....is a little much...Labor rates...ugh....
Thankfully they send me the coupons for 10% OFF in the mail every 3 months or so... With the coupon 15K service is $211.00
Remember- If you always take your car to the dealer to get the work done, if anything is ever jacked up by them (oil plug not tight or some of the other horror stories I've heard) they are responsible without any question since they have all the records on the car....this has saved me a few headaches and $$$ in the past...
2003.5 G35 Sedan, Caribbean Blue, Sport
1994 MustangGT w/ 347 Street Fighter 382.4HP & 411.2 lb/ft
Old Mar 18, 2003 | 07:59 AM
VNT's Avatar
VNT
Re: Oil Change
I read 3750 miles for the coupe.
I check my friend's Z....it also says to use a mineral based oil, like the G35c.
Old Mar 19, 2003 | 03:22 AM
dubi_V35's Avatar
Re: Oil Change
the dealer didnt recommend synthetic oil for this car ,and i forgottto ask why.
www.derubeisfineart.com
Old Mar 19, 2003 | 03:23 AM
dubi_V35's Avatar
Re: Oil Change
i got the plan that gives me life time oil changes for free i wonder if i covers all the other stuff you guys are talking about.
Old Mar 19, 2003 | 09:03 AM
Msedanman's Avatar
O.F. Administrator
Re: Oil Change
Hey dude, Yeh that 168 bucks sounds a bit 'rich' for checking this and that and rotating the tires. Wow, I'd say maybe 1 to 1.5 hrs tops for labour. Our labour rates here in Ontario are generally about 70/hr. Maybe they're higher where you are.
When they serviced the brakes they should have lubricated the sliders, pins, and contact points. That could account for another half hr..My schedule says only front brakes but maybe they did all 4. It's a good idea to do them especially in my lousy climate.
Check it out with the service guys, maybe there's more done than we realise. Good luck.. [img]/w3timages/icons/smile.gif[/img]
<font color=red>GSM</font color=red>
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
