Misfire on cylinder 6!
well i was changing out my spark plugs today, and on cylinder 6 taking out the plug there was oil on it, and i mean lots! it was like to the top, so i replace the plug. put everything back together and cylinder 6 was misfiring. im thinking i need to replace the valve cover and after that everything should be fine, anyother suggestions? i know i put the coil packs in back in the rights spots because i did the plugs one at a time putting it back together right away. im really worried right now! someone please help me! im almost positive its the valve cover that needs to be replaced, but with alot of oil in the cylinder 6 spark plug would that cause a misfire? thanks!
Originally Posted by 1SlowG35Sedan
Ouch, there should be a tsb on that. Some VQ engines where plagued with that problem. If you're still under warranty go take it in, they will replace your valve cover.
Originally Posted by garry101
well im out of warranty, so no luck there, but im going to infiniti tomorrow and put up a fight and see if corporate will do something for me!
Good luck with that bro, keep us updated.
i had that problem also and they say that it was a gasket. the car should cover that up to 70,000 miles since it is a tranny problem. got it fix at no charge i went in wen i had about 67,xxx miles
It's not a tranny problem....
Originally Posted by uf20wop
it is a powertrain though, covered up to 70,000 miles
plus there is a TSB about this
Originally Posted by Klubbheads
Did the car also loose lots of power after certain RPM?
