Misfire on cylinder 6!
Old Nov 14, 2008 | 01:31 PM
garry101's Avatar
it was noticeable once i took out the coils, and then the spark plug was soaked, i used the oem ngk plugs laser platinum
Old Nov 14, 2008 | 01:35 PM
SDGenius's Avatar
same thing happened to me, it was the valve cover
Old Nov 14, 2008 | 01:37 PM
garry101's Avatar
thats kind of relieving! lol im headed to the dealership right now and ill update as soon as i can
Old Nov 14, 2008 | 01:41 PM
Jeff92se's Avatar
Red Card Crew
p/n on plugs? Thanks
SD, did you notice any performance loss?
Old Nov 14, 2008 | 01:53 PM
SDGenius's Avatar
^^^yeah, a small blip at 6k RPMs but other than that, no. felt a lot better after it was fixed though but i also switched to one step colder plugs.
Old Nov 14, 2008 | 07:46 PM
garry101's Avatar
haha thats great, well i went to infiniti and they wont do ****, so i bought the valve covers and gaskets from riverside infinit (Thanks Rick!) and im having my mechanic install it for me for 80!
Old Nov 14, 2008 | 10:13 PM
garry101's Avatar
Another update, i went again and took out the coil pack for cylinder six cleaned it w a rag, put everything back together, and start the car up and what do ya know, everything goes back to normal, what a sigh of relief! but im still going to change out the valve cover, because there was oil in the spark plug thing.
Old Nov 16, 2008 | 02:58 AM
Mr. Samster's Avatar
sorry!... thats what i meant powertrain not tranny i dont know why i said that
Old Nov 16, 2008 | 09:34 PM
godmans's Avatar
Please keep us all updated on this since this problem seems to be getting more frequent.... and most of us won't check our plugs until another 50k miles.
G/L with the fix tho!
Old Nov 17, 2008 | 12:24 AM
garry101's Avatar
no worries...and yea for sure, i ordered the parts from riverside infiniti, should be here on wednesday, and im going to install them probably on friday, but as of right now i got cylinder 6 to work again!
Old Jul 10, 2016 | 06:50 PM
HRG3N3RAL's Avatar
Originally Posted by garry101
well i was changing out my spark plugs today, and on cylinder 6 taking out the plug there was oil on it, and i mean lots! it was like to the top, so i replace the plug. put everything back together and cylinder 6 was misfiring. im thinking i need to replace the valve cover and after that everything should be fine, anyother suggestions? i know i put the coil packs in back in the rights spots because i did the plugs one at a time putting it back together right away. im really worried right now! someone please help me! im almost positive its the valve cover that needs to be replaced, but with alot of oil in the cylinder 6 spark plug would that cause a misfire? thanks!
Bruh.. I found solution to what your experiencing.. And share this. If you find oil in spark plug tube you'll find it in cylinders 4,5 and 3 as well.. The oem valve covers have irreplaceable tube seals.. So u need to by aftermarket valve covers with the replaceable rubber seals.. U can get em from z1 motor sports with the gaskets for almost 400$. Now in addition to this I got all new spark plugs(changing them is how I found the problem) and all new ignition coils(+3-500).. As well an all new intake gaskets and an oil change... Once all together ran perfectly no leaks with the exception of the cylinder 6 misfire.. I just cleared the codes and pulled the coil and dos spark test.. It passed and I noticed I just didn't have it plugged in properly(always triple check your work).. I put it back in properly and now it runs perfectly fine like the day I pulled it out the lot.. Hope this helps.. If not and you plug in scan tool and find that your getting fuel and spark but showing poor results on power balance test you'll need to run a compression test because it's been a thing that the compression rings can go out or u may have worn valve guides.. Initially it'll run shitty cuz of the oil that will fall into chamber on re installation but once it wakes up and circulates you should be good.. Mine was sitting for weeks while I waited for parts and it still good.. Good luck brother I know the feelings of the struggle in this and it should have been on recall..
Old Jan 11, 2023 | 02:34 AM
Jorge Flag's Avatar
Completely stock besides headlights
You can actually replace the rubber rings from the valve cover but not with the infiniti ones, the ones that fit perfectly are from a honda civic 2010, i did replace one of my valve cover gaskets because i had oil everywhere including cylinder 4 and 6 and there where no rubber seals at all when looking at them, i looked it up on youtube and i found that information, so instead of getting new valve covers i expend like 20 at most and it has been working perfectly fine, hopefully this helps somebody
Old Jan 13, 2023 | 06:24 AM
Scorpi0's Avatar
Need more info on this. Please explain what u did.
Old Feb 10, 2023 | 09:08 AM
Jorge Flag's Avatar
Im sorry for the delay on my answer, i hope it will help, so i was doing my driver side valve cover gasket and i notices that the seals were missing, my dad helped me and he got the ones for infiniti but they were way to big, so i looked up on youtube and found a guy explaining that you can use the ones from a 2010 honda civic, so i went to autozone and got those, they come 8 in the pack but you can only use 4 becase the other 4 will be loose, so if u replace all 6 u will need 2 packs, so far i have had no problems, no leaks or anything, i will try to find the name of the video so i can put it up here, since the guy explain way better than me
Old Feb 10, 2023 | 01:23 PM
  #30
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
This is probably the video he's referencing.
dat_skyline
Sep 19, 2016 01:05 PM
rolson1
Jun 16, 2014 08:48 PM
dias724
May 18, 2010 01:43 PM
revo_uti_ons
Mar 29, 2010 07:35 PM
Jhonatansc
Sep 8, 2009 12:54 AM
