New stillen radiator now fans always on???
Old Nov 14, 2008 | 09:55 PM
minh420's Avatar
Hey i just had the new stillen radiator installed and i also replaced the thermostat and water pump at the stame time. My car doesn't over heat at all but it seems like once my electric fan kicks on it never shuts off. Before the fan would turn on then off once it reaches temperature. Any suggestions?? i tried searching already. Thanks
Old Nov 15, 2008 | 12:41 AM
minh420's Avatar
ttt
Old Nov 15, 2008 | 12:53 AM
rookie's Avatar
The cooling system is a little tough to bleed. No temp sensor doesn't help either. High side comes on at 210 or something in that neighborhood. Do you have heat at idle?
Old Nov 15, 2008 | 11:19 AM
minh420's Avatar
the weird thing is my temperature gauge never goes above the normal half way point. When i first installed the radiator i did have trouble bleeding the air but i got it out. I don't think there is still air in the system. So if i try to turn the heat on at idle it should make the temp go down?? I'm thinking of getting a nismo t-stat. Is it ok to run on a NA motor??
Old Nov 15, 2008 | 09:24 PM
Canadian's Avatar
Canada, eh?
The stock gauge is very inaccurate. It will stay below halfway at its normal area from I believe about 160-230ish degrees. It sucks to measure temps with.
Old Nov 17, 2008 | 11:26 AM
Q45tech's Avatar
Read the REAL coolant temp via OBD2 data scan........the inside gauge is just a feel good indicator not to be relied upon.
Picture Share
Feb 4, 2018 12:41 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
BradMD_96
Oct 6, 2015 09:31 AM
Learned Hand
Oct 1, 2015 09:02 AM
