Serious Fuel Smell....
Old Nov 16, 2008 | 02:39 PM
hyperlite21's Avatar
did u just install hfc's or test pipes?
Old Nov 16, 2008 | 02:42 PM
weslutes's Avatar
SGP racing return fuel system
There could be your problem. Tighten the lines. If the SS lines are exposed, they have a tendency to smell. I believe the CJM FR uses Teflon
Old Nov 16, 2008 | 05:13 PM
G37Rider92649's Avatar
Procharger ftl
Haha the fuel return might be your problem, or heck it may be the tune? I dont know but hope you solve the problem and update us when you do!!
Old Nov 16, 2008 | 05:25 PM
Mr_pharmD's Avatar
Like everyone state, it's probably the return line. I have the AAM one and it stinks of gas fume vapors when I have a full tank of gas. Damn u AAM for lying!!!
Old Nov 16, 2008 | 07:38 PM
Canadian's Avatar
Canada, eh?
This probably isn't what it is, but takes two seconds to check so it wouldn't hurt. It also has nothing to with your AC/heat being on.
Check the top left of your engine, the multi-colored thing (I believe its the fuel regulator?). Mine as leaking before because the o-ring had went bad. You will obviously see fuel leaking out of it thats the case, I know mind was leaking and would leave a terrible smell. Took 5 minutes to fix too.
Old Nov 19, 2008 | 01:21 PM
breftayka's Avatar
Ay Homie! Mine is the same way, I took it into the dealership under warranty and they said everything was normal... I thought it was running too rich, but apparently its what its supposed to be doing...
Old Nov 20, 2008 | 01:50 PM
GreenGoblin's Avatar
The goblin resurrection
I hope you dont smoke in the car.
Old Nov 24, 2008 | 01:31 PM
breftayka's Avatar
I love that smell... Your complaining about it? j/k
You find anything out?
Old Nov 24, 2008 | 01:44 PM
waijai's Avatar
i.love.gold
Seems pretty straight forward...you smell gas, so check all your connection in your fuel system. And I don't mean just a visible "oh it looks tight".
Old Nov 24, 2008 | 05:43 PM
waijai's Avatar
i.love.gold
You can have a leak and not visibly see fuel. Your fuel return system has been brought up as a possible suspect, so that's the first thing to check. It's gotten colder, so fittings and connections may leak b/c parts will expand & contract.
Bottom line is you just have to go check instead of asking people what it could be.
btw...car needs a drop
