Suggestions for Modifications?
Old Nov 21, 2008 | 02:24 PM
rushg35's Avatar
for a 2004 g35 looking to buy air intake, intake manifold/spacer, headers, high flow cats, exhaust. Preferably Carb legal stuff but is doesn't matter, i'm open to all ideas.
Old Nov 21, 2008 | 03:23 PM
Boston's Avatar
Skip the intake and keep the OEM airbox unless you just want it for looks. Get a 350Z tube and a 5/16th spacer or aftermarket upper plenum. Headers will give you performance gains but a pain in the a** to install. HFC's are a good way to go (Fast Intentions or Crawford) coupled with a cat back exhaust (Fast Intentions or HKS). Just my suggestions.
Old Nov 23, 2008 | 08:35 AM
paulhappvincent's Avatar
I put in an injen short ram induction system, a 5/16 spacer and they alone made quite a dfference. I want to put in a bigger guage Y pipe and eventually a full exhaust system. I think that it is better to go one step at a time to see what each alteration feels like instead of all out in one go.
Old Nov 23, 2008 | 03:33 PM
rushg35's Avatar
thanks alot guys. just wondering what do you suggest on the spacer/ plenum there's alot out there
Old Nov 23, 2008 | 03:54 PM
Canadian's Avatar
Canada, eh?
http://motordyneengineering.com/G35.php
First one on the page there. Then a Z-tube/pop charger. Also headers aren't worth the trouble as it is a PITA x 100 to install them. I don't know about HFC, but get the megan v2 resonated test pipes. Exhaust? Thats up to which sound you like.
Old Nov 24, 2008 | 02:09 PM
I agree. the motordne is a good part. If however the cost is something that affects your decision, blox make a part that is a lot cheaper and simpler to install and gives nearly as good a result.
Old Nov 25, 2008 | 02:49 PM
AllNatural's Avatar
if you plan on goin f/i in the future. then you should just skip the spacer for now and get a intake manifold. Pairing it with the sc to tc will give you more gains than a spacer.
Picture Share
Feb 4, 2018 12:41 PM
Rose M
Oct 12, 2015 10:00 AM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
