Variable Timing Sensor question
Old Dec 8, 2008 | 05:16 PM
Taurkon's Avatar
Question Variable Timing Sensor question
My wife indicated to me last week that the 03' G35 was ticking pretty good. After a few questions, I find that it has been ticking pretty good for a few weeks now, but ticking in some degree for the last few months, although some days more noticable than others.
I brought it to my mechanic (who does not charge $140/hr like the dealerships do), and after some discussion with him, and some discussion on his behalf with the dealership, they agreeed that it is lifters, but possibly due to a Variable Timing Sensor failure.
Has anyone had any experience with engine "ticking" caused by the VTS?
Thanks!
Old Dec 8, 2008 | 06:46 PM
canucklehead's Avatar
the maintenance schedules call for valve adjustments when valvetrain noise becomes excessive. most likely you just need an adjustment.
Old Dec 8, 2008 | 09:49 PM
OCG35's Avatar
the bucket/tappets/sometimes called lifters - do wear over time... if you have 60K or more its possible that the lash is a bit loose and needs adjusting (meaning the worn buckets need replacing or shimmed) - not an easy or cheap thing to do trust me.
If its excessive you should go ahead and get it done - if its a light tap and you are sure its not piston slap it wont cause a problem, just more a nuisance than anything. I'm dealing with the same thing every since I had cams installed.
Old Dec 8, 2008 | 10:42 PM
03sedan6speed's Avatar
This may sound silly, but check the oil. I had the same problem. There is a bulletin out for this problem from Infiniti. Topped off the oil and it was fine. This actually led me to find out that my 03 was burning 1 quart ever 600 miles! I have pasted the bulletin.
And another thing... you cannot do a simple valve adjust on these motors. You must remove the cams and lifters which alone is roughly 15 hours flat rate.
So in conclusion check your oil level!
Classification:
EM06-006a
Reference:
ITB06-023a
Date:
January 24, 2008
APPLIED VEHICLES:
All 1997 2008 with Variable Valve Timing
APPLIED ENGINES:
VQ35; VH41, VK45; VK56
IF YOU CONFIRM
The MIL is on with any of the following DTCs stored:
^ P0011, P0014, P0021, P0024, P1110, P1135,
NOTE : The engine may also have Camshaft Sprocket rattle noise and/or other engine noise.
ACTION
Do Not replace the variable valve timing Solenoid Valve or the Sprocket(s) without performing the complete diagnostics indicated in the EC section of the Service Manual.
The first steps in the complete diagnostic are to make sure the:
^ Engine oil is at the operating level; add oil if needed. Refer to the Service Manual for low oil level diagnoses if needed.
^ Oil pressure is normal when measured with a gauge at the pressure switch port. Refer to the Service Manual for low oil pressure diagnoses if needed.
Old Jan 15, 2009 | 09:39 PM
1beastnstl's Avatar
AWD Sport with Tech
warranty work?
Old Jan 16, 2009 | 06:04 PM
ttrank's Avatar
Grocery getter
Originally Posted by 1beastnstl
warranty work?
Nope.
Old Jan 16, 2009 | 06:09 PM
1beastnstl's Avatar
AWD Sport with Tech
Originally Posted by ttrank
Nope.
we THAT sucks. any ideal how much that adjustment would cost? i'm not having ANY issues with mine and for some reason, the oil change seemed to get rid of my "service engine soon" light. (also had belts replace and brake flush all at 56k)
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
KevinnnVo
Jul 28, 2015 06:29 PM
newg37
Jul 26, 2015 09:32 AM
