Stillen engine damp
Old Dec 31, 2008 | 04:25 AM
butkiss1's Avatar
Stillen engine damp
Installed the stillen engine damper today ,took about an hour. Got every thing put back together , went for a test drive ......... Tha g felt slower....... Not as quick ......... 4 days ago i did my throttle body cleaning and plugs , i was quick ....... But not today..... Could it be the heat?..........waited till dark went for a drive @47 degrees ......the g was slower and less responsive than ever before ........ What changed..?.........i thought about it....... The only thing that changed was that one ground wire. You have to move the stock ground wire to another mounting bolt just above the old position and that mounting spot is some type of anodized metal .....so just as a test i reattached the ground wire back to the original position. I just bent the copper plate to straighten it so it would fit. Went for a test drive........wow.........i'm back.......... Gobbs of power.............. I have gords 10 wire grounding kit ......i don't know jack about how a grounding kit works......... But i know that gords 10 wire set works....... Could repositioning the stock ground change the way the way that the grounding kit works?........... I know my car .....there was a difference .......... Any thoughts
Old Dec 31, 2008 | 07:55 AM
uf20wop's Avatar
......... dunno
Freeman186
Sep 6, 2023 10:07 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
Joe Gargano
Sep 18, 2015 11:17 AM
Jnm07
Sep 5, 2015 01:16 AM
