pop charger install instructions!?
Old Jun 8, 2004 | 10:59 PM
Raznips's Avatar
i saw the picture "instructions" in the DIY. I really understand words better than pictures.... well picture + words best. I feel most comfortable with the ztube instructions that i found and feel good about installing my ztube when it gets here later this week. I have the pop charger on the way too and dont really feel 100% about it yet. I'm sure i can figure it out and im thinking that if i dont feel POSITIVE before i start by looking at it... i'll just take it somewhere (infiniti aftermarket shop down the street). If someone just wrote me some words to that popcharger install ( http://www.performancenissanparts.co...ide/g35pz.html ) found there. How hard is this install u guys think? I just really want some written instruction before i tear apart my beatiful g and screw something up
2004 Black on Black g coupe 6spd.... <3 aluminum pedals, clear corners, z tube, and pop charger. From down south, houston tejas
Old Jun 9, 2004 | 09:17 AM
Gordgee's Avatar
Administrator
Re: pop charger install instructions!?
The hardest part of the Pop-Charger install is putting n the rubber flaps on the heatshield. The rest is quite easily done with minimal skills.
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Jun 9, 2004 | 11:44 AM
mamboking's Avatar
watch out for the MAF rubbing the A/C line. Protect the A/C line with a piece of rubber hose and a small clamp to keep it in place. There are tons of info about this on this forum.
Old Jun 9, 2004 | 11:48 AM
mamboking's Avatar
Here is a picture of what I am talking about.
Old Jun 9, 2004 | 06:45 PM
Raznips's Avatar
yes i know about the ac line and stuff..... i did my research and everything I just was thinking maybe someone could hook up some pointers and stuff.... i dunno i guess i'll figure it out sometime this week whe it all gets here
2004 Black on Black g coupe 6spd.... &lt;3 aluminum pedals, clear corners, z tube, and pop charger. From down south, houston tejas
Old Jun 9, 2004 | 07:34 PM
neffster's Avatar
mamboking,
What size "insulation tubing" did you use and what exactly is that material called? Your a/c line fix looks to be the cleanest of all fixes that I've seen (and dabomb is my buddie and his is not that clean [img]/w3timages/icons/tongue.gif[/img]).
301-bhp!!! ...and growing!
Old Jun 10, 2004 | 10:28 AM
mamboking's Avatar
Thanks neff, I used what I believe is 1/4 inch fuel line rubber hose. It is very sturdy. There was another type of hose with the same inner space but it was orange (air compressor hose) and I decided to go with the fuel line which is black. I think the foot is like 90 cents at Lowes. Then I went and got the 2 smallest clamps I could find. The funny thing is that I cut a piece of the rubber hose which is about 6 inches in length to cover the A/C line. While installing it, I discover that if put the clamp right where the rubbing takes place, the clamp itself became another barrier between the MAF and the A/C line. You can do my fix even cleaner by just cutting like one inch and using one clamp right where you forsee the contact to take place.
Old Jun 10, 2004 | 10:49 AM
neffster's Avatar
THANKS!
Old Jun 11, 2004 | 04:56 PM
Raznips's Avatar
OOOO NOES!!! my popcharger arrived today.... im at work right now and wont be home till like 7:30.... i dont wanna take my stuff all apart and not be able to finish the install after all.... can someone plz write a little explanation for each of those pics above or SOMETHING!? Or should i just start taking it apart while looking at the pictures and hope for the best? actually.... i think i coulld prolly take out and put back in my stock air box if i had to..... its really just the pop charger install that im no 100% on...... what do u guys think?
Old Jun 12, 2004 | 01:26 AM
Buster77's Avatar
Hey man, I did it with my good buddy about 2 weeks ago. My advice is this. Just look at the pictures, make sure you have the right tools, and make sure YOU HAVE ALL THE PARTS before you install. The place i bought from forgot to send me the bracket that held the filter element in place to the chasis...that was great considering i realized it when everything else was done. Have confidence in yourself. This is the EASIEST mod to do...long black pipe connected to a filter...which in turn connects to your car...doesnt get much easier. If you really need help, you can message me and Ill walk you through it some how...
Old Jun 12, 2004 | 01:39 AM
GeoBau's Avatar
Cactus Hugging Admin
After reading the DIYs and looking at the pics, it probably took me a grand total of 15 minutes to install the thing... just do your homework and you'll be fine. Also, have all the tools handy... big plus.
G
2003.5 Black w/ Willow G35
Premium / Sport / Aero / Winter / Navi / Tint
<font color=blue>Z-tube, Pop-charger, Borla True-Dual Exhaust, Eibach Pro Kit, GroundingGear</font color=blue>
Old Jun 12, 2004 | 03:34 AM
gdupg35's Avatar
George, for SOME reason, I was under the impression that it takes 9 1/2 hours to install the thing. Or is that just with certain installers?
Old Jun 12, 2004 | 01:19 PM
TCFOOL's Avatar
Was fairly straight forward.. took me about one hour or a little more.. took my time and just made it a cool relaxing install.
TC
"There is a Very Fine Line Between "Hobby and Mental Illness"
Old Jun 12, 2004 | 02:37 PM
kelven33033's Avatar
pop-charger is dangerous!!
filtration is really bad.
if you don't want your engine after 150000 miles, then go ahead and keep on using it
Old Jun 12, 2004 | 02:39 PM
neffster's Avatar
...said the pop charger grinch. How many threads are you going to post this in w/o any data to back up this statement???
Geesh...
