A got to have item...
Old Jun 10, 2004 | 09:18 PM
jjellyneck's Avatar
Re: A got to have item...
...and if the ECM forces the car into limp mode due to the increased air caused by an aftermarket plenum, it truly does not need to force the limp mode. This is mainly because the front 2 cylinders are now receiving the air that they should be receiving! Bummer.
So there would really be no need to change the fuel maps, just the need to tell the ECM not to worry about the increased air. Something like that.
'04 6MT coupe
Old Jun 10, 2004 | 09:57 PM
Catatafish's Avatar
Nice lesson Dave.
BTW,
Doug has told me that Technosquare is working on an ECU flash geared towards the Crawford Package. Won't be long from what I hear. My mods are on hold until I can get a reflash. I don't want my ECU to get grumpy.
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5
Old Jun 11, 2004 | 09:27 AM
Daniel_G's Avatar
Not to say this is a bad product, but I use Autotap if I want to see all these features....and with Autotap you could log this info...and save it, clear codes(SES), etc. Autotap connects to either your laptop or palm. lol....I sound like I work for Autotap.
Monitors:
A/C System Refrigerant Monitoring Status
Auxiliary Input Status
Catalyst Monitoring Status
Comprehensive Component Monitoring Status
ECT
EGR System Monitoring Status
Engine Load
Engine Load
Engine Speed
EVAP Vent Solenoid Command
Evaporative System Monitoring Status
Fuel Pressure
Fuel System Monitoring Status
Fuel System Status Bank 1
Heated Catalyst Monitoring Status
IAT
Ignition Timing
LTFT B1
LTFT B2
MAF
MAP
Misfire Monitoring Status
O2 Sensor - B1S1
O2 Sensor - B1S1 (mV)
O2 Sensor - B1S2
O2 Sensor - B1S2 (mV)
O2 Sensor - B1S3
O2 Sensor - B1S4
O2 Sensor - B2S1
O2 Sensor - B2S2
O2 Sensor - B2S3
O2 Sensor - B2S4
OBD Requirements
Oxygen Sensor Heater Monitoring Status
Oxygen Sensor Monitoring Status
Secondary Air System Monitoring Status
STFT B1
STFT B2
Throttle Position
Vehicle Speed
http://www.autotap.com/products.html
http://www.villagephotos.com/pubbrow...elected=551133
Old Jun 11, 2004 | 10:11 AM
SixFive's Avatar
That stuff looks cool but no laptop for me or palm. I keep the radio off to focus on driving and that would be the end of me if I started fing with my palm while driving.
By the way the TS guys emailed me with a reduced price of $174 including shipping....nice eh
Just tell them your from G35driver or its 195 plus shipping or something.
2003.5 DP 5AT Sedan (E-thing but Nav)
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Jun 11, 2004 | 10:14 AM
DaveO's Avatar
Daniel_G,
From what I can tell, both the Autotap and pocketlogger come with a CD and connector cable. According to the information on their websites, they provide much more information than the little Techtom unit.
I looked into code readers a while back and saw the Autotap and Pocketlogger. I passed on both because I didn't want to be driving around with my laptop in the front seat while making test runs. And I don't want to buy a PDA... at least for now.
That's not to say Autotap is a bad product of course.
DaveO
03 G35 AT Sedan / DP / Willow / Premium / Sport / Aero
350Z Air Duct, Eng Cvr & T-Stat / Stillen CAI
Crawford V-5 / GG 10-Wire Kit / TS ECM / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
Old Jun 11, 2004 | 10:21 AM
DaveO's Avatar
Catatafish,
I really don't think your ECM will get "grumpy" by adding of the normal N/A mods. A 99% reliable rumor has it that the 04 cars ECM's are much more complex and control off a wide band O2 sensor's input.
SoCalTed is running the latest "Crawford" TechnoSquare ECU program. You can checkout his (247hp) dyno sheet posted elsewhere on G35Driver. Not a bad number for an N/A AT Sedan in my opinion.
DaveO
Old Jun 11, 2004 | 01:09 PM
DaveO's Avatar
Need favors from those folks who have the Techtom CMX-100 N2, pocketlogger, etc.
Please provide your intake air temperatures at idle, low speeds and approx. how long it takes to cool down after you get to highway speeds.
If possible I'd also like the same information from the stock G35 air intake system, as well as the JWT Popcharger w/heat shield, Injen, AEM, Nismo and K&N systems.
This information should benefit our collective knowledge.
DaveO
Old Jun 11, 2004 | 01:45 PM
SixFive's Avatar
Someone may also (i will time permitting) try out two different intakes same day within an hour or so so the ambient temp is the same and the results comparable and perform the ti time it takes to cool test. Problem will be getting the car cooled under the hood to the exact same temp for each run. Maybe i should get it hot as hell before each run by doing a couple WOT highway jaunts rather than try to let it cool to a certain temp.
14.2 @ 97.18
Z-Tube
UR Crank Pulley
Old Jun 11, 2004 | 02:13 PM
al503's Avatar
any info on the group buy?
Old Jun 11, 2004 | 04:36 PM
Msedanman's Avatar
O.F. Administrator
I heard back from Danny at Technosquare today:
Colin,
The price for G35Driver.com will be 165.75 + shipping. Retail is $195.00 + shipping.
Danny.
<hr></blockquote>
Good price and no need for G/Buy.
Dave - did you get the reduced price?
Colin
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Jun 11, 2004 | 05:18 PM
al503's Avatar
this might be another good alternative:
http://www.pocketlogger.com/index.php?pid=plobdii
It seems to be able to do the exact same things but you will be able to save all of the information in your palm pilot/pc, not just the peak values. With the serial cable, it'll be just around $200.
Old Jun 12, 2004 | 09:26 AM
DaveO's Avatar
For those who are going to help with the "heat soak" test we'll probably need a list of parameters.
Heres a completed example of my first test for your consideration.
Car: 03 G35 Sedan
Air Intake System: Stillen CAI w/Popcharger air filter & Z-tube - System, including MAS Air Flow sensor, is fully insulated.
Ambient Temp (dash readout): 75F
A/C System: Off
Radiator Fans: Off
Water (Coolant) Temp: 190F - 200F
Intake Air Temp @ Idle for 3 minutes: 128F
Intake Air Temp @ 70mph: 84F
Approximate Cool Down Time: 3+ Minutes
DaveO
Old Jun 13, 2004 | 11:04 PM
6t8stang's Avatar
While not real time, I use this and am happy:
http://www.davisnet.com/drive/produc....asp?pnum=8220
Nice and compact. You can find them on the web cheaper than $179...
2003 G35 Coupe 6MT
Brilliant Silver \ Willow Leather
Gilbertsville, PA
Old Jun 15, 2004 | 12:54 AM
DaveO's Avatar
Alagolfer and I spent part of today insulating the back of his Popcharger's velocity ring (picture above) and comparing the temperature profiles of his insulated JWT Popcharger and Z-tube vs. my insulated Stillen CAI system and Z-tube.
Please note: We don't present this info as absolute. These are the numbers we got while driving both cars throughout the day.
Alagolfer's 03.5 G35 Sedan
Air Intake System: Popcharger w/heat shield & Z-tube - Back of the velocity ring, MAS Air Flow sensor and Z-tube are fully insulated.
Ambient Temp (dash readout): 97F
A/C System: On
Radiator Fans: On or Cycling.
Water (Coolant) Temp: 190F - 210F
Intake Air Temp @ Idle for 5 minutes: 134-138F
Intake Air Temp @ 60mph: 116F
Approximate Cool Down Time: 2+ Minutes
Note: Pre-insulating the V-ring numbers - 82F air temp & 114F idle temp.
DaveO's 03 G35 Sedan
Ambient Temp (dash readout): 98F
A/C System: On
Intake Air Temp @ Idle for 2+ minutes: 112-115F
Intake Air Temp @ 60mph: 107-109F
Alagolfer noted throughout the day his temps were about double what mine were. For example: At idle, when the Stillen system was about 15F above ambient temp, the Popcharger’s temps were 30-35F above ambient. At 60mph the insulated Popcharger system was an average of 10F higher than the insulated Stillen system.
Next up... the stock air case with an insulated Z-Tube.
We'd still like to get info on a non-insulated Popcharger - Z tube, a K&N Short Ram, and an Injen, AEM, or Nismo system. FYI, the pavement temperature in front of the house was 155F with a 90F air temp. We didn't get it at 98F.
DaveO & Alagolfer
Old Jun 15, 2004 | 01:22 AM
  #30
alagolfer's Avatar
Dave, it feels great to be back at sea level. The altitude and temperature at your place sucked all the horsepower out of my car. Thanks again for all the help.
2003.5 Black 5AT Sedan
z-tube/ jwt popcharger/crawford plenum/crawford cats/
stillen exhaust/grounding kit/e-fans
technosquare ecu /350z thermostat/double din
