Car Starts Up Then Dies. HELP!!!!!!!!!!!
Old Jan 27, 2009 | 08:56 PM
alliedtech's Avatar
with my foot off the gas as i start my car up it seems like its fine then as the idle goes to level out the rpms just dorp and it dies, unless as i start it up i give it a little gas then it idle levels out and it seems to run fine. and some times if i rev the engine as it goes to idle again it almost dies.
Old Jan 27, 2009 | 11:00 PM
05DGx's Avatar
Try cleaning out the MAF and the throttle body. That might help some.
Old Jan 27, 2009 | 11:03 PM
pattyskin's Avatar
I had this exact same problem, my throttle body was replaced under powertrain warranty. They tried a few things first and nothing worked, they tried replacing some O2 sensors, idle air control motor, and something else, then finally just replaced the whole throttle body and fixxed it.
Old Mar 28, 2009 | 08:51 PM
graphite6mt's Avatar
any update?
Old Mar 28, 2009 | 11:53 PM
Law to the Rence's Avatar
any mods?
i had a similar condition after installing the plenum spacer but after fixing the vacuum leaks, its fine
Old Mar 29, 2009 | 06:00 PM
Gordon's Avatar
I'm currently experiencing the same problem, only happens when the engine is warmed up. Have no problems with startup when the engine is cold.
Recently replaced clutch (Exedy) and flywheel (ACT Prolite). Tried an ECU reset, but the problem still occurs after the reset.
Old Apr 22, 2009 | 11:10 PM
MadMonkey's Avatar
sounds like you might need a new MAF same thing happened to me 3 weeks ago. replaced it and now it's fine.
Old Apr 22, 2009 | 11:39 PM
nghiars's Avatar
MAF sensor is either dirty or faulty
Old Apr 26, 2009 | 11:29 PM
Gordon's Avatar
Ended up doing an idle reset and a throttle body service and no longer have the issue.
Old Apr 27, 2009 | 11:17 PM
Kev'sLaserRedG's Avatar
did ur check engine light come on and a couple of other lights when u start the car cause mine seems to be doing the same thing by the way its 6 speed tranny. thanks for any ideas.
Old May 4, 2009 | 03:58 PM
pwebb's Avatar
these cars are known to have throttle body issues...
not sure how well the MAF holds up with aftermarket intakes...
Old May 5, 2009 | 02:02 PM
Doc_Yizz's Avatar
I had this exact issue during a considerable part of my warranty. I had it serviced twice and the issue persisted. The third time it was finally resolved. I'll check my service invoices to see what they did.
BTW, *knock on wood*, I havent had any related issues since.
Old Jun 21, 2009 | 05:59 PM
tonke73's Avatar
I had this problem but it was due to a bad crankshaft sensor on a 300zx.
Old Jan 16, 2011 | 11:01 PM
G35CV35SKYLINE's Avatar
I'm having this exact same issue don't mean to bump this thread but was wondering if the OP ever had this fixed or if anyone here knows there is a definite fix to this problem? Was the TB the problem?
Old Mar 15, 2011 | 08:09 PM
djb703's Avatar
Any one? Just replaced my starter, had the battery off the car for 3 days, now i have this issue which i never had before.
