? ABOUT ECU RESET AFTER TS ECU INSTALL
Old Jun 15, 2004 | 03:00 PM
ramo's Avatar
i had a question about the ecu reset after you install the technosquare ecu. i was wondering if i can just do to +/- battery terminal touch method instead of the way it shows in the ts website?
Old Jun 16, 2004 | 06:16 PM
InfinitiTech's Avatar
Re: ? ABOUT ECU RESET AFTER TS ECU INSTALL
do the battery cable disconnect and touch and hold them together for five second routine, that is the best
Infiniti Gearhead
Old Jun 17, 2004 | 04:01 AM
GurgenPB's Avatar
Yep this works!
Old Jun 17, 2004 | 03:02 PM
ramo's Avatar
okay after i installed my ts ecu, i touched the + and - cables for 5sec. but i am wondering if i am supposed to notice a big difference in performance after the chip? i have a borla exhaust, crawford plenum, crawford cats, injen intake, grounding wires.
Old Jun 22, 2004 | 11:49 PM
n1cK's Avatar
G35 6MT
i don't think i understand....touch the positive and negative terminal of the battery together? isn't that bad?
n1cK
jUs' bE [img]/w3timages/icons/cool.gif[/img]
Old Jun 23, 2004 | 07:36 PM
KPierson's Avatar
They are talking about touching the terminals together when the battery is disconnected. Basically, this will drain any compacitive loads in the system by shorting them directly to ground. Something I personally wouldn't want to do to my electronics.....
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Jun 24, 2004 | 10:18 PM
n1cK's Avatar
G35 6MT
ah, i see. hey KPierson, do you mean "capacitive?" that runs the risk of damage some of the components in the circuit though....i guess if the discharge of the capacitors were of small enough current, then it would be okay, but sounds too risky.
n1cK!
ps-KPierson, what's the status of makin' new window roll-up boards?
Old Jun 25, 2004 | 06:11 AM
KPierson's Avatar
Yeah, I meant capacitive, as in the capacitors that would store enough current to keep enough power in the ECU for it to 'keep' its memory. Without knowing exactly how many and what size caps there are in the car it is impossible to determine the risk involved, but I would much rather find another way to reset the ECU. I just hope someone with a 1F cap for thier stereo doesn't try this!!!!!
Kevin
AIM: KPiersonTec
Old Jun 25, 2004 | 06:15 AM
KPierson's Avatar
N!ck,
I've got one of the new boards in my car right now, and I've sent out about 5-6 of them for a quick 'test.' It will be about another week before we are ready to ship out the next shipment, as I have all the inventory with me in Baltimore, Md, and my brother ships them from Columbus, Ohio.
Kevin
AIM: KPiersonTec
Old Jun 25, 2004 | 05:54 PM
n1cK's Avatar
G35 6MT
ouch, that would hurt!!
i also hear that you are planning on makin' a remote start unit that works with the oem remote (i think i heard that from daniel). is that true? that would be nice, really nice!
n1cK
Old Jun 25, 2004 | 05:58 PM
n1cK's Avatar
G35 6MT
oh by the way kevin, i sent in my order and payment today. let me know when you get it. thanks!
n1cK
Old Jun 25, 2004 | 05:59 PM
roneski's Avatar
Devil's Advocate
I think that the battery technique will reset all of the settings on your stereo too though.
mike730
Jan 12, 2018 04:25 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Silver tiburon
Sep 4, 2015 07:17 PM
leli_11
Aug 10, 2015 08:25 PM
kenthung
Jul 21, 2015 05:56 AM
