Installing HKS DLI and NGK Spark Plugs today (need some advice)
Old Feb 7, 2009 | 03:16 PM
g35man04's Avatar
CLUB MODERATOR
Like the title says....wanted to get some advice from some members who have installed the HKS DLI....Where is the best place to mount the controller box to get a good ground?? also does anyone have a picture of the the HKS DLI installed?? I am trying to determine where to start so then I can determine what plugs go where.....
I will take some pics during the process to maybe show a write up of how to do the HKS DLI install along with the spark plugs.
I will let you know how everything goes as well with results from power etc.....I wish I had the grounding kit as well to install when I do this but unfortunately I dont...
Any advice/picture anyone can give that would be great!!!
Old Feb 7, 2009 | 06:00 PM
superchargedg's Avatar
This is the only pics i have of it from when i still had the stillen s/c.Went with the Greddy twins and its still in the same spot...hope it helps.
Old Feb 7, 2009 | 06:06 PM
Lone Wolf's Avatar
let us know how it turns out.
Old Feb 7, 2009 | 06:08 PM
badtziscool's Avatar
Sorry for my ignorance. What does the DLI do? Increase spark power?
Old Feb 7, 2009 | 06:11 PM
Yes.
Old Feb 7, 2009 | 06:13 PM
g35man04's Avatar
CLUB MODERATOR
im installing my NGK plugs today as well...so hopefully this will help out my car.
Old Feb 7, 2009 | 06:56 PM
g35man04's Avatar
CLUB MODERATOR
this is what I have to deal with right now...
As you can see they are not numbered....
Im assuming they plug in fairly easy to the OEM wiring harness....each plug to the connectors right?
Is this where I am tieing them into?
Im plugging the wires into these Technically:
Old Feb 7, 2009 | 07:28 PM
SDGenius's Avatar
i got mine mounted like this...
Old Feb 7, 2009 | 07:35 PM
SDGenius's Avatar
oh, here's a better pic...
Old Feb 7, 2009 | 07:56 PM
g35man04's Avatar
CLUB MODERATOR
I am talking about the wiring itself....mine isnt labeled for me to know which one goes to what.
Old Feb 7, 2009 | 08:01 PM
SDGenius's Avatar
the connector on the longest end goes to the furthest plug, the rest fall in after
Old Feb 8, 2009 | 03:07 AM
g35man04's Avatar
CLUB MODERATOR
well I followed your directions and now I am having random cylinder misfires and the car is idling like crap....
Old Feb 8, 2009 | 04:23 AM
g35man04's Avatar
CLUB MODERATOR
here is mine installed from front left to front right.
First Plug:
Second PLug:
Third Plug:
Fourth Plug: Back Right coil under throttle body
Firfth PLug:
Sixth plug:
Old Feb 8, 2009 | 10:16 AM
g35man04's Avatar
CLUB MODERATOR
thanks man...really quick..I unplugged all of it and plugged back up the OEM wires...my car seems to be idling fine now but I hear occasional popping from the exhaust....could this be because of the many times I started the car trying to determine what was the correct path for HKS DLI wires?? Meaning to much fuel in the system? Also I realized after changing my spark plugs lastnight that I was running NGK 1 Step Colder plugs on my NA engine for awhile now....(installed by infiniti when I put the new engine in) which I know is not good...so I put the OEM spec of NGK into the car...Should I do an ECU Reset, Throttle body re-learn and timing Re-learn?
Old Feb 8, 2009 | 10:18 AM
SDGenius's Avatar
did you route the wires behind the engine or in front???
