Anyone got a coupe/z thermostat on their sedan
Old Feb 10, 2009 | 12:18 AM
4drmadness's Avatar
hey guys anyone got a z or coupe thermostat. if yes, how hard was the install? how are you liking it. for a whopping 20 bucks, im willing to give it a shot
Old Feb 10, 2009 | 01:27 AM
DaveB's Avatar
Don't bother unless you want to screw around with trying to get all the air bubbles out of the cooling system after you do this. If you're looking for a way to lower cooling system temps, consider getting the OEM higher pressure radiator cap from a 300ZXTT. It will essentially do the same thing, but for cheaper and a lot less work.
Old Feb 10, 2009 | 01:32 AM
4drmadness's Avatar
where could i get one of those radiator caps?
Old Feb 10, 2009 | 08:56 AM
sloppymax's Avatar
I have one. Install was easy and I did not drain the system. I did have air bubbles but purging the system of air was easy with the plug. I bought an aftermarket 300zx TT radiator cap to go along with the 350z/coupe thermostat but the seal was really crappy and was leaking. Never went to Nissan to get an oem one.
Old Feb 10, 2009 | 11:27 AM
DaveB's Avatar
Nissan dealership
Old Feb 10, 2009 | 02:36 PM
ttrank's Avatar
Grocery getter
Do you mean the Nismo thermostat? I thought the oem one was the same for all three cars.
Old Feb 10, 2009 | 04:32 PM
sloppymax's Avatar
Originally Posted by ttrank
Do you mean the Nismo thermostat? The oem one is the same for all three cars.
The FSM shows the sedan to have a higher rated t-stat than the coupe and z, at least for 03-06. Different part numbers showing the different temps shows in the FAST catalog.
Old Feb 10, 2009 | 05:10 PM
Canadian's Avatar
Canada, eh?
You should buy the Nismo, it is better. I see constant lower temps with it.
Old Feb 10, 2009 | 05:34 PM
ttrank's Avatar
Grocery getter
Wow, I didn't know that. I thought they were all the same.
Old Feb 10, 2009 | 07:58 PM
4drmadness's Avatar
I just got a thermostat from a g coupe (sport model). is this the same as the z?
Old Feb 10, 2009 | 08:06 PM
rookie's Avatar
Opening temp is on the thermostat, look for a Celsius rating.
Old Feb 10, 2009 | 08:12 PM
4drmadness's Avatar
oh cool, so it should say 170 right.
Old Feb 10, 2009 | 08:14 PM
rookie's Avatar
170c is pretty hot, it should say something in the 70s
Old Feb 10, 2009 | 08:27 PM
Canadian's Avatar
Canada, eh?
I think he meant 170F?
Old Feb 10, 2009 | 08:29 PM
rookie's Avatar
The stamp is in Celsius. My mental calculator is broken. lol
