Md 5/16 instal....help!!
Old Feb 19, 2009 | 07:18 PM
lfaboulos34's Avatar
just installed my md 5/16 spacer. i have a problem. i used all the bolts that came with the kit besides 2 bolts. i couldn't screw them in because of this...take a look and tell me how to take these "screws" off so i can put in the 2 bolts...here are pics..
Old Feb 19, 2009 | 07:21 PM
JBF's Avatar
JBF
You're gonna have to take the upper plenum back off and the spacer. Take one nut from those and thread it head first. Take the other one and thread it normal. Then take an open ended wrench and loosen it with the bottom nut.
Hope that makes sense.
Or get a Star socket that fits it.
Old Feb 19, 2009 | 07:23 PM
WILLIE BEANS's Avatar
tamper-resistant torx screw???
Old Feb 19, 2009 | 07:25 PM
hmmm i dont really understand
JBF's Avatar
JBF
Torx bit...ha I couldnt think of it a minute ago.
Old Feb 19, 2009 | 07:26 PM
JBF's Avatar
JBF
Find a torx bit that will fit that and you should be good to go. I had to improvise with that other method.
Old Feb 19, 2009 | 07:28 PM
Texasscout's Avatar
It's in the directions on MD website. screw on one nut, then a second as a "lock" nut tighten them togeather and use that as a "bolt head" to remove it.
Old Feb 19, 2009 | 07:29 PM
thanks so it will unscrew from the bottom rite?
Old Feb 19, 2009 | 07:31 PM
JBF's Avatar
JBF
Try lookin at this
http://www.motordyneengineering.com/manual.pdf
Old Feb 19, 2009 | 07:33 PM
i get it now...so will i have to take of the plenum or can i do it with in on?
TORX SOCKET SET LOOKS LIKE THIS ..
Old Feb 19, 2009 | 07:35 PM
ShanesG's Avatar
if you dont have that star type socket you have to take it off, screw 2 nuts on it and unscrew the bottom nut, the stud will unscrew!
JBF's Avatar
JBF
If you get torx bits you can leave it on. but if you do it the other way, you gotta take it off
Old Feb 19, 2009 | 07:39 PM
thanks a lot for the help guys!!
Old Feb 19, 2009 | 07:45 PM
gary c's Avatar
That's so strange, I didn't have those torx bolts on my plenum when I installed my spacer. Must have been something the factory had laying
around when they put this one togeather....LOL I was ready too, I have
that socket set. When your other car's a Vett you can't live without the
whole set....
Gary
