Loctite for MREV2 install
Old Mar 3, 2009 | 06:47 PM
irishsig's Avatar
I'm going to install the MREV2 and need Loctite.
Anyone know which Loctite thread locker I should use for the bolts?
I went to the Loctite website and there's about 28 types of the thread locker.
Old Mar 3, 2009 | 06:58 PM
lilindienplaya's Avatar
when you go to your local hardware store or home depot type store there will only be like 2-3 different types you need the blue type its removeable the red is permanant so stay away from that. Actually those are the only two ive seen in stores.
Old Mar 3, 2009 | 07:01 PM
irishsig's Avatar
Cool, thanks man.
Can't wait to do this install this weekend.
Old Mar 3, 2009 | 07:06 PM
no prob its pretty straight forward, the kit should already come with a tube of loctite mine did atleast.
Old Mar 3, 2009 | 07:10 PM
xXHotelCrazyXx's Avatar
Go with the blue. Most mfg's use it on the assembly line.
Old Mar 4, 2009 | 02:19 PM
irishsig's Avatar
I guess they would have this at Trak Auto or Home Depot?
Old Mar 4, 2009 | 02:20 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Yes.
Old Mar 4, 2009 | 04:43 PM
tiguy99's Avatar
What they said ^ ^
Old Mar 6, 2009 | 10:56 PM
grouchandeligh's Avatar
loctite
pretty sure you want the 242 if its the blue. Medium strength and I'm pretty sure the higher the number the stronger it holds. I use this stuff at work for mechanical assembly and I have to warn you, you really only need a few drops. I put one single drop on number 4 through number 8 screws. You're using a larger screw but I wouldn't over do it.
Old Mar 6, 2009 | 11:02 PM
Heist.'s Avatar
drop or two per bolt! Get the blue stuff its not cheap so don't waste it.
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
