Tried search button already, Motordyne Install
Old Mar 4, 2009 | 08:39 PM
Telly9987's Avatar
I recently installed a 5/16th motordyne copper iso thermal spacer. I accidently started the car and decided to try and drive without plugging in MAF. I immediatly got a check engine light. After trying the battery reset I still have the light. Not able to get a scanner on the car for a day or 2 and need to drive to work.
Also what does your car idle at? I drop down to 500 rpms at stop? Help
Any suggestions??
Please advise.
Old Mar 4, 2009 | 09:31 PM
keff108's Avatar
Normal idle is between 650 and 800 I believe.
Old Mar 4, 2009 | 10:14 PM
twin001's Avatar
how long did you leave the battery disconnected? Your MAF is plugged in now right? Did you do it on purpose or accident? Your idle should pick back up after a few miles of driving. Did you make sure you had all the hoses reconnected?
Try going to Autozone or a similar parts store and have them read/clear the code.
Old Mar 4, 2009 | 11:01 PM
Telly9987's Avatar
Thanks guys I got my hands on a scanner and it was all maf codes. Cleared the codes and no CEL. What are expected whp gains? I dynoed at 284. Projected? I also get a drastic drop in RPMs when I stop, (drop to 500 and raise). Ideas?
Old Mar 4, 2009 | 11:19 PM
twin001's Avatar
You dyno'd at 284? Wow, that's a high number. What mods do you have? I know different dyno's read different, but damn, that's high.
Old Mar 4, 2009 | 11:29 PM
Telly9987's Avatar
Dynojet. 284.00 will post pics of dyno sheet asap. dyno again tomorrow since the spacer install.
Old Mar 4, 2009 | 11:45 PM
Telly9987's Avatar
http://my.picresize.com/3506YGQ6TV i cant get the picture to post!!!!
Old Mar 4, 2009 | 11:54 PM
keff108's Avatar
list your mods please cuz those are good numbers
Old Mar 4, 2009 | 11:57 PM
Telly9987's Avatar
nothing really.... pop charger z tube....... that gave me 284 and ill have the numbers tommorow night including the spacer... graph has a decent line as well i think.
Old Mar 5, 2009 | 01:20 AM
chinabean's Avatar
weird...that IS pretty high..
Old Mar 5, 2009 | 11:06 PM
Telly9987's Avatar
Just re-dynoed.... 295.2 will post dyno chart later tonight....
motordyne 5/16 copper iso therm
jwt pop
stillen z tube
93 oct pump
dyno jet
40 degrees outside temp
Old Mar 6, 2009 | 05:23 AM
chinabean's Avatar
^ 93 octane...idk
Old Mar 7, 2009 | 12:17 PM
alic4nte's Avatar
ummm congrats on those numbers? kinda high for N/A
Old Mar 9, 2009 | 04:55 AM
chinabean's Avatar
nobody else chiming into this? lol
Old Mar 9, 2009 | 09:45 PM
Telly9987's Avatar
