Spark Plug Questions!
Ok so everyone knows i searched and couldnt find anything good on here about spark plugs....
I dont know how old my plugs are in the car but from me alone are 14k miles and 1 year old from the previous owner!!!
I want to just put new plugs in!
I know this car has coil packs and im pretty sure i have stock plugs in right now.
What are good spark plugs that run well with this engine????
my truck i always used bosh platimum +4 plugs.... i know they now have PLATINUM IR FUSION plugs but these were generaly for GM and German cars got best results.....
What plugs do you guys use LET ME KNOW And if someone has a nice forum on changing the plugs would be helpful since i have not yet done or attempted this job on this car yet
Thanks
Thanks
dude you dont upgrade plugs unless you go FI then you go one step cooler depending on the psi
ENVautoDetailing.com
ngk platinums are stock and ngk iridiums are what most people replace them with. I just replaced mine last week after 67,000 miles and luckily my valve covers aren't leaking yet. Make sure you change them before the powertrain warranty is up (70k) if you dont then you'll be stuck paying a ton in labor to replace the valve cover gaskets.
-GP-
-GP-
yosip1115
Aug 20, 2015 10:30 PM
yassy
Aug 9, 2015 07:31 PM
