HP Output Question
Old Jun 27, 2004 | 01:21 PM
eldy's Avatar
HP Output Question
When an engine is rated at X hp @ Y rpm are the hp values only valid at WOT?
Rephrase:
If our engines are running at 6200 rpm with only 75% throttle is it still outputting 280 hp?
Old Jun 27, 2004 | 02:07 PM
BrianV's Avatar
Re: HP Output Question
Yes you have to be at WOT.
04 6MT Sedan - Z Tube, Stillen CAB, 04 Z Suspension
Old Jun 27, 2004 | 08:41 PM
Q45tech's Avatar
With electronic throttle control you never know exactly what the real throttle plate via the throttle motor is doing.........unless you look at OBD2 voltages.
When you floor the inside throttle the ecu decides at what rate it will open the real throttle.
Realistically you must monitor the MAF voltage and rpm to calculate an approximation of HP/TORQUE.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
