Help..check engine light
Old Jun 26, 2004 | 03:46 AM
ColdFusion's Avatar
I installed my injen cai today and the check engine light went on. Does anyone know why its on or what i can do to make it turn off? There doesnt seem to be anything wrong with the car cuz its pulling like crazy.
Old Jun 26, 2004 | 05:28 AM
neffster's Avatar
Re: Help..check engine light
An intake performance increase should be equivalent to this scenario...
Before you have the intake is similar to driving with a light weight passenger.
After you install the intake it should be similar to driving without that light weight passenger in the car.
If you've noticed more gains than what I've just described then you probably have a problem with your MAF sensor. It could be a number of things, like you're running leaner/richer than before, there are aliens in your engine bay making your car run faster, you're nuts [img]/w3timages/icons/tongue.gif[/img], etc...
You could try to reset the ECU, but I'm not too much of a believer in that, especially with the 6MT's. I bet the light will go off pretty soon.
Oh, did you turn the car on without the MAF sensor hooked up? That would definitely make your dash light up.
301-bhp!!! ...and growing!
Old Jun 26, 2004 | 11:12 AM
Msedanman's Avatar
O.F. Administrator
Try doing the pedal method of resetting the ECU -- IN HERE.
Should work provided there is no other problem causing the light.
G/L
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Jun 27, 2004 | 11:35 PM
ColdFusion's Avatar
okay, i tried resetting the ecu using the pedal method and now the light is gone. Thanks for the help =)
Ednica87
Sep 5, 2015 02:59 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
