Oil cooler go good investment for a Vortech S.C.?
Old Jun 30, 2004 | 10:27 PM
MEEKOPEEKO's Avatar
Reading posts in various forums about vortech s.c. kit on 350z + G's, I found people said the down side to the kit that that it runs engine oil from the pan to the sc which heats it up even more and is bad on the engine and sc. heat = less power and more wear on engine. Would an oil cooler solve this "down side" on the vortech?
Old Jul 1, 2004 | 12:08 AM
dklau33's Avatar
Re: Oil cooler go good investment for a Vortech S.C.?
IMO, an oil cooler would be a good investment to keep your FI investment and engine in safe shape. An oil cooler is pretty pricey though but sometimes necessary for those who track their cars hard. Another cheaper alternative would be to get an oil pan with more capacity or an oil pan spacer kit. Both would allow more total oil in the sytem, usually 6+ qts.
ARC Oil Pan
http://www.performancenissanparts.co...roducts_id=685
JWT Oil Pan Spacer Kit
http://www.performancenissanparts.co...roducts_id=741
04' G35S 6MT Ivory Pearl, Willow, Premium
Z-Tube / NFC Y-Pipe / Custom Mid-Pipe / 350 EVO Rear Sway
Old Jul 1, 2004 | 12:21 AM
G35TRex's Avatar
IMO, get both.On the long run it'll be will worth it. Also give you a peace of mind.This is all from experience.Also a fin oil pan w/ large capacity is another possibilty....although pricey about $450 the fins does help the cooling.
Old Jul 1, 2004 | 12:32 AM
lucidazn's Avatar
<html><a href="
http://www.performancenissanparts.co...roducts_id=335">Oil Cooler</a>
Wow $1,325... expensive
'04 Ivory Pearl G35 coupe 6MT Fully Loaded /w Navigation
Brooklyn, NY
Old Jul 1, 2004 | 12:59 AM
MEEKOPEEKO's Avatar
Nismo -oil cooler 1300$, stillen- 350$ why such a difference in cost? they do the same thing
Old Jul 1, 2004 | 04:35 PM
BigRon's Avatar
I haven't looked at the two, but there's likely a size difference and possibly a difference in grade of materials used. And one isn't stamped with the NISMO logo. [img]/w3timages/icons/wink.gif[/img] And keep in mind, most competent mechanics can install an oil cooler for you for pretty cheap by using a plain-Jane cooler and good lines and fittings. I'd take a kit just for simplicity's sake, if the price was right. I couldn't justify spending more than $350! The Jeggs or Summit catalog would come out and an alternative solution would be found, pronto! lol
'05 IP(or ?) 6MT... ...Never too soon to think about modifications!!
Old Jul 2, 2004 | 11:36 AM
3point5SE_Auto's Avatar
Ok, first step is to figure out if you need one. You do this by installing an oil pressure gage and an oil temperature thermometer. Stick em somewhere out of the way, as you won't need em every second, but somewhere you can look at em from time to time.
If your oil pressure gets low (see ESM for minimum) add a cooler. If you see oil temps too high, likewise get a cooler. If not, your current cooler will be fine.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, HyperGround Kit, Magnaflow resonator.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
newg37
Jul 26, 2015 09:32 AM
