HELP! my car throttles on its own when slowing down.
Old Apr 1, 2009 | 01:22 AM
raydeon's Avatar
Question HELP! my car throttles on its own when slowing down.
my car throttles on its own, from 800ish RPM to 1200ish RPM for at least twice for very short time (half of a second), everytime when slowing down.
is it some sort of special feature of 05 G35 that i've never heard of?
what would u suggest ? taking it back to the dealer since it's still under warranty ?
thank you
Old Apr 1, 2009 | 01:26 AM
elayman's Avatar
downshifting lol
Old Apr 1, 2009 | 01:28 AM
raydeon's Avatar
Originally Posted by elayman
downshifting lol
for real? i've had other automatic shift cars before but never experienced such thing heh....
anyways, i am a noob to the Gs
Old Apr 1, 2009 | 10:47 AM
maciejk's Avatar
isn't that normal that the car will have slighty higher revs when it shifts to a lower gear, at least that's how it is with a 6mt, is that when it happens when u feel it shift gears?
Old Apr 1, 2009 | 11:27 AM
elayman's Avatar
Mine doesn't do it all the time but maybe sedans do? Mine downshifts sometimes when slowing down slowly or when I slow down and accelerate again
Old Apr 1, 2009 | 11:32 AM
Blue Meanie's Avatar
Old Apr 1, 2009 | 01:25 PM
DaveB's Avatar
Have you messed around with the throttle body recently? When it does the rpm fluctuation, can you feel a slight surge below 5mph?
Old Apr 1, 2009 | 02:50 PM
ttrank's Avatar
Grocery getter
Are you sure it's not just rev-matching when it down shifts?
Old Apr 1, 2009 | 04:03 PM
raydeon's Avatar
how can i tell if if was just a rev-matching or not?
what's rev-matching ?
Old Apr 1, 2009 | 04:05 PM
When you move down the gears, (in manual, or auto), the revs will jump, as the the engine speed will be higher for that speed, in that gear. It's the same principle as heel and toe. So, when you go down the gears the revs will jump each time it goes into the lower gear.
Old Apr 2, 2009 | 10:53 AM
sliderg35's Avatar
It would help to know what year and trans you have?!?! (I'm guessing auto because of your comment, but the year would tell if you should see rev-matching or not.)
Old Apr 2, 2009 | 01:03 PM
raydeon's Avatar
yeah, it's a AT, 2005 sedan.
Old Apr 2, 2009 | 02:45 PM
DaveB's Avatar
Have you messed around with the throttle body. If so, I know the answer on how to fix your problem. I've had the same thing happen before.
Old Apr 2, 2009 | 04:00 PM
raydeon's Avatar
no, i didn't touch nothing on the throttle. but i am bringing the car in to the dealership this Sat.
Old Apr 2, 2009 | 04:06 PM
dofu's Avatar
20 Year Member
Try resetting the ECU... just unplug the negative for 5-10 minutes to be sure and reconnect it and try. I'm probably thinking it's what DaveB is trying to ask you about... Your throttle body position sensor is just going whack... If resetting your ECU doesn't help, then it's something else.
