Thermostat
Old Apr 8, 2009 | 01:37 PM
ckg35's Avatar
Thermostat
I did a search and couldn't find anything. Is there a DYI for changing the thermostat somewhere? Can we use a generic or just the Nissan? Easy to do on our cars?
I think my 'stat is getting lazy and I guess it's time for a change.
TIA
Old Apr 9, 2009 | 02:05 PM
ckg35's Avatar
No one has changed their thermostats?
I just thought I'd ask here before taking things apart, so any help or feedback would be appreciated.
Old Apr 9, 2009 | 02:30 PM
G37Rider92649's Avatar
I did, switched to a Nismo thermostat. I dunno how to install it though lol, had gtm do it when they did the rest of my cooling project.
Old Apr 9, 2009 | 02:45 PM
ckg35's Avatar
I would guess that the Nismo is lower temp? Any other advantages?
Old Apr 9, 2009 | 03:06 PM
ttrank's Avatar
Grocery getter
Yes it just opens earlier.
Old Apr 9, 2009 | 05:14 PM
DaveB's Avatar
Why do you think your T-stat is lazy? Have you recently changed the coolant? Usually a stat doesn't get lazy. It either works or it doesn't. It's a super simple device. I suggest removing it and testing it via the FSM procedure before throwing down the cash for one. If you want to lower coolant temps, an change is just to add the radiator cap from a 300ZXTT.
Old Apr 15, 2009 | 02:51 PM
ckg35's Avatar
I noticed during the cold weather that though I got heat while I was moving, when I stopped and the car was at idle, my heater would be blowing cold. On the move, blowing warm air again. My reasoning was that the coolant wasn't getting by the thermostat at idle, but while moving, there was enough pressure to open it up.
Faulty thinking on my part? Any other suggestions?
Also, I haven't had the chance (also too lazy right now) to look under the engine cover. Where is the 'stat located in our cars and how easy is it to get at? Will a generic type fit, or is it one of those that is integrated into a housing of some sort?
TIA
Old Apr 16, 2009 | 05:20 PM
ckg35's Avatar
Hmmm. No answers here.
I guess I'll have to take a look at it this W/E.
Old Apr 16, 2009 | 05:25 PM
DaveB's Avatar
It's quite possible the issue you're having is related to a vacuum or weak vacuum solenoid. Under the dash (passenger side) is box with a door what opens and closes between the heater core or AC evap based on if you want hot or cold air. This door is often vacuum actuated with vacuum solenoid. At idle, vacuum is high and depending on throttle input, vacuum will rise and fall. If there is a leak or actuator problem, the door's operation will be inconsistent and may vary with speed. This exact problem you're describing is quite common with cars, especially Jeep GCs. I'm unsure if the G uses vacuum or an electronic motor to operate the blower door. I believe the door is accessible once you remove the lower passenger dash (do a search for cabin filter replacement). It is possible something might be blocking the door, not letting the unit distribute heat correctly at idle.
Old Apr 16, 2009 | 05:43 PM
Q45tech's Avatar
Nissan thermostat are of a design that fails open or always leaks a little [rubber surround]. Common for long warm ups, low heat temp to be a leaky thermostat.
Usually they last 6 years.
Old Apr 16, 2009 | 06:40 PM
ttrank's Avatar
Grocery getter
Could also be air in the cooling system, you may just need to purge the air.
Old Apr 22, 2009 | 02:43 PM
ckg35's Avatar
Time to change mine out anyway. Looks like Nissan recommends replacing the thermostat and the housing as a complete unit!
I thought I saw some separate thermostats that would fit, but I guess you'd have to disassemble the unit to make it work. Not worth the trouble if so.
Thanks for your help and suggestions guys.
seagrasser
May 3, 2022 09:43 AM
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
Jay123
Sep 28, 2015 08:42 PM
Usman Ali
Sep 22, 2015 06:59 AM
NohoG35revup
Aug 22, 2015 12:13 PM
