Wheels Vibrate at low speed
Old Apr 9, 2009 | 09:26 PM
DEEZ_G35's Avatar
Hey guys I just bought a 06 Coupe AT has 41k miles on it...Iv noticed once in a while when I press on the gas a little the wheels and shifter vibrate then when i let go of the gas peddle it goes away..Does anyone know what would be wrong..I still do have the factory warranty on the car an was thinking of taking it in..wanted to see if it has happened to others...The tires are still brand new an alignment looks good
Old Apr 10, 2009 | 04:12 PM
Theanimedude's Avatar
definitely a messed up alignment, take it back and tell them to fix it. shops sometimes mess up alignments.
Old Apr 28, 2009 | 10:38 PM
longdyslik's Avatar
it could be that ur front tires tred is worn out on the inside facing the engine....i had that problem and got new tires and everythin was a.o.k
hope this help
Old Apr 29, 2009 | 12:52 AM
DEEZ_G35's Avatar
Thanks guys I got an alignment done this past weekend and vibration is not that much...im going to try to get my wheels balanced again
Old Apr 30, 2009 | 11:42 AM
sliderg35's Avatar
If your wheels are balanced and you still get vibration, it's because the wheels are not on properly. This happens often. Just take them off and reinstall using the correct bolt pattern for tightening. I've had to do this after the dealer worked on the car.
MyfistYourFace
Aug 8, 2015 11:58 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
rping
Jul 26, 2015 09:53 PM
ddietz97
Jul 26, 2015 06:16 PM
