03 coupe: vdc, slip, check engine light on after changing spark plugs
Old Apr 12, 2009 | 12:06 PM
rus023's Avatar
03 6sp coupe
Just changed all spark plugs and one coil, reset the ecu, car drives fine for about an hour, then some kind of hard knock happenes and all the lights(vdc,slip,check engine) come on.I have to crank for 5 sec just to start it,also acceleration very bad, rpm's hesitate and drop slowly when in neutral.
What is that? Any help appreciated
Old Apr 15, 2009 | 03:49 PM
Kirb36's Avatar
I also have that problem. Haven't changed anything, when i went to turn on my car, the same lights came on, rpms fluctuate while in neutral and my speedometer doesn't work either, i checked all my fuses and am about to try a ecu reset. Any help would be great, ill check back after ecu reset.
Old Apr 16, 2009 | 09:03 AM
djamps's Avatar
Codes, anyone?
Old Apr 16, 2009 | 09:15 AM
rus023's Avatar
problem fixed, happened to be a camshaft position sensor
Old Apr 21, 2009 | 02:57 AM
mikeyngo's Avatar
Where is the camshaft position sensor located? I'm having the same problem..
Muski_G
Dec 1, 2023 11:11 AM
ghost_g35
Aug 7, 2015 10:31 AM
ClwMike
Jul 23, 2015 12:55 PM
Jadenkid22
Jul 14, 2015 12:33 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
